Dell XPS 15 9510 Fan Replacement
  1. Dell XPS 15 9510 Fan Replacement, Rear Panel: step 1, image 1 of 1
    • Make sure the laptop is powered off and unplug all cables before beginning any repair.
    • Remove eight 3 mm screws from the underside of the case using a T5 Torx screwdriver.
  2. Dell XPS 15 9510 Fan Replacement: step 2, image 1 of 1
    • The metal case of the XPS 15 9510 is extremely sharp, so be careful not to run your fingers along the edge when disassembling the laptop.
    • Wedge the case apart with a nylon spudger.
    • If the plastic one isn't possible to insert, use the metal spudger to carefully create a small gap first.
    • Slide spudger along each side of the laptop
  3. Dell XPS 15 9510 Fan Replacement: step 3, image 1 of 1
    • Lift the back panel of the laptop off and set it aside.
  4. Dell XPS 15 9510 Fan Replacement, Fan: step 4, image 1 of 2 Dell XPS 15 9510 Fan Replacement, Fan: step 4, image 2 of 2
    • Remove two 4.3 mm screws from the left fan and one 4.3 mm screw from the right fan using a JIS #000 screwdriver.
  5. Dell XPS 15 9510 Fan Replacement: step 5, image 1 of 2 Dell XPS 15 9510 Fan Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Gently unplug the motherboard fan connector using a pair of tweezers.
  6. Dell XPS 15 9510 Fan Replacement: step 6, image 1 of 1
    • Unplug the motherboard connector on the other fan using a pair of tweezers.
  7. Dell XPS 15 9510 Fan Replacement: step 7, image 1 of 2 Dell XPS 15 9510 Fan Replacement: step 7, image 2 of 2
    • Gently slide and then lift the fans out of their positions.
  8. Dell XPS 15 9510 Fan Replacement: step 8, image 1 of 3 Dell XPS 15 9510 Fan Replacement: step 8, image 2 of 3 Dell XPS 15 9510 Fan Replacement: step 8, image 3 of 3
    • Repeat the previous step and remove the other fan.
2 other people completed this guide.
Bethany Wright
403 Reputation
3 Guides authored
IUPUI, Team 2-1, Harley Summer 2023 Member of IUPUI, Team 2-1, Harley Summer 2023
IUPUI-HARLEY-SU23S2G1
4 Members
3 Guides authored
0 Comments
Past 24 Hours: 5
Past 7 Days: 13
Past 30 Days: 55
All Time: 637
