Dell XPS 15 9560 Battery Replacement
  1. Dell XPS 15 9560 Battery  Replacement, Back Panel: step 1, image 1 of 1
    • Using a T5 Torx screwdriver, remove ten 4.0 mm screws from the back panel of the laptop.
  2. Dell XPS 15 9560 Battery  Replacement: step 2, image 1 of 1
    • Using a Phillips #2 screwdriver, remove two 5.0 mm screws underneath the XPS badge door.
  3. Dell XPS 15 9560 Battery  Replacement: step 3, image 1 of 1
    • Wedge the scribe between the backplate and remove the bottom base cover.
  4. Dell XPS 15 9560 Battery  Replacement, Battery: step 4, image 1 of 1
    • Using a T5 Torx screwdriver, remove the six 4.0 mm screws.
  5. Dell XPS 15 9560 Battery  Replacement: step 5, image 1 of 1
    • Unplug the battery cable.
  6. Dell XPS 15 9560 Battery  Replacement: step 6, image 1 of 1
    • Remove the battery.
For optimal performance, after completing this guide, calibrate your newly installed battery.
8 other people completed this guide.
Jada Houser
790 Reputation
7 Guides authored
Clemson, Team 4-5, Hunter Fall 2021 Member of Clemson, Team 4-5, Hunter Fall 2021
CLEM-HUNTER-F21S4G5
4 Members
15 Guides authored
One Comment
If you have an additional HDD you need to use the type H5H20 instead of the 6GPTY. The configuration as shown in picture 6 isn't possible with the 6GPTY unless you're willing to remove the HDD.
Tim - Reply
Past 24 Hours: 11
Past 7 Days: 74
Past 30 Days: 318
All Time: 9,315
