Dell XPS 15 9570 Fan Replacement
  1. Dell XPS 15 9570 Fan Replacement, Base Cover: step 1, image 1 of 1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 Fan Replacement: step 2, image 1 of 3 Dell XPS 15 9570 Fan Replacement: step 2, image 2 of 3 Dell XPS 15 9570 Fan Replacement: step 2, image 3 of 3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 Fan Replacement: step 3, image 1 of 2 Dell XPS 15 9570 Fan Replacement: step 3, image 2 of 2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 Fan Replacement: step 4, image 1 of 1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 Fan Replacement, Battery: step 5, image 1 of 1
    • Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
  6. Dell XPS 15 9570 Fan Replacement: step 6, image 1 of 1
    • Use the iFixit opening tool to disconnect the battery connector from the motherboard.
  7. Dell XPS 15 9570 Fan Replacement: step 7, image 1 of 1
    • With your hands, pick up and remove the battery from the system.
  8. Dell XPS 15 9570 Fan Replacement, Fan: step 8, image 1 of 2 Dell XPS 15 9570 Fan Replacement, Fan: step 8, image 2 of 2
    • Use the Phillips #00 screwdriver to remove the two 4 mm screws securing the grey display cable bracket.
  9. Dell XPS 15 9570 Fan Replacement: step 9, image 1 of 1
    • Using the Phillips #00 screwdriver, remove the 4 mm screw at the back right corner of the fan.
  10. Dell XPS 15 9570 Fan Replacement: step 10, image 1 of 2 Dell XPS 15 9570 Fan Replacement: step 10, image 2 of 2
    • Disconnect the fan cable on the left of the fan and on the right side from the RAM, using the opening tool.
  11. Dell XPS 15 9570 Fan Replacement: step 11, image 1 of 1
    • Lift the right fan off of the device.
    • Repeat steps 8-11 to remove the left fan from the system board.
    • The left fan is fixed with two 4 mm screws. Make sure you have removed them if the fan does not come off easily.
Clay Caldwell
348 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 27
Past 30 Days: 151
All Time: 5,197
