DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement
  1. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement, Input Jack Port: step 1, image 1 of 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement, Input Jack Port: step 1, image 2 of 2
    • First, open the metal stand to access the screws without damaging the body.
  2. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: step 2, image 1 of 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: step 2, image 2 of 2
    • Remove the 3 outer 1.2 mm Phillips #1 screws using a small head screwdriver.
  3. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: step 3, image 1 of 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: step 3, image 2 of 2
    • Remove the back casing to reveal the inner circuitry.
  4. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: step 4, image 1 of 1
    • Locate the different parts of your tuner, finding the broken input jack port.
  5. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: step 5, image 1 of 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: step 5, image 2 of 2
    • Snip the wires attached to the input jack port using the wire cutter as close to the input jack port as possible.
  6. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: step 6, image 1 of 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: step 6, image 2 of 2
    • Take your new input jack port and solder the wires to the corresponding connection areas on the new port.
    • Learn how to solder (here).
  7. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: step 7, image 1 of 2 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: step 7, image 2 of 2
    • Fold the wires back and put the new input port into the slot where it belongs on the tuner.
  8. DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: step 8, image 1 of 3 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: step 8, image 2 of 3 DeltaLab CT-40 Chromatic Tuner Input Jack Port Replacement: step 8, image 3 of 3
    • Replace the casing and 3 1.2 mm Phillips #1 screws using the screwdriver.
Finish Line
Theodore Tan
137 Reputation
1 Guide authored
Cal Poly, Team 23-4, Green Winter 2015 Member of Cal Poly, Team 23-4, Green Winter 2015
CPSU-GREEN-W15S23G4
7 Members
15 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 4
All Time: 535
