Desktop PC RAM Replacement
  1. Desktop PC RAM Replacement, Left Panel: step 1, image 1 of 1
    • Unplug the computer from the power supply before any maintenance or disassembly.
    • Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
    • These screws can usually be removed by hand.
    • Be sure to wear an anti-static bracelet or use an anti-static mat to ensure important components are not damaged by static electricity.
  2. Desktop PC RAM Replacement: step 2, image 1 of 2 Desktop PC RAM Replacement: step 2, image 2 of 2
    • Next, remove the side panel of the computer case to allow access into the computer. Slide the panel towards the back of the computer and lift it up to remove.
    • If there is a fan mounted on the side panel, make sure to unplug the cable before fully removing the panel.
  3. Desktop PC RAM Replacement, RAM: step 3, image 1 of 1
    • Unlock the RAM by pressing down on the tabs from either side of the RAM that are securing the RAM to the socket.
  4. Desktop PC RAM Replacement: step 4, image 1 of 1
    • Carefully remove the RAM sticks from the computer casing.
    • Repeat the above step and this step as necessary. Some computers could have many sticks of RAM.
  • When replacing the RAM, place the replacement into the RAM slot and lock the tabs in.
53 other people completed this guide.
David Lennon
9,998 Reputation
10 Guides authored
Cal Poly, Team 4-5, Maness Spring 2015 Member of Cal Poly, Team 4-5, Maness Spring 2015
CPSU-MANESS-S15S4G5
4 Members
45 Guides authored
4 Comments
can you remove the heat spreader on a corsair vengence led ram?
scar0134 - Reply
very interesting
maciekErd123 - Reply
how to determine the speed
benzy aceware - Reply
how can i differentiate between types of rams
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 53
All Time: 7,163
