Disassembling Canon PowerShot SD1100 IS Front and Rear Cover
Tyler Grossheim
Tyler Grossheim and 3 other contributors
Last updated on January 28, 2014
10 minutes
Easy
Introduction
Go to step 1
Use this guide to remove the front and rear cover of the Canon PowerShot SD1100 IS.
Tools
  1. Disassembling Canon PowerShot SD1100 IS Front and Rear Cover, Front and Rear Cover: step 1, image 1 of 2 Disassembling Canon PowerShot SD1100 IS Front and Rear Cover, Front and Rear Cover: step 1, image 2 of 2
    • Remove wrist strap and battery.
  2. Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: step 2, image 1 of 3 Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: step 2, image 2 of 3 Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: step 2, image 3 of 3
    • Remove 2 screws from each side of the camera (4 total, 0.102 in).
    • Remove 2 screws from the bottom on the camera (0.138 in).
    • Do not mix the 4 side screws with the 2 bottoms ones; they are different sizes.
  3. Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: step 3, image 1 of 3 Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: step 3, image 2 of 3 Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: step 3, image 3 of 3
    • Gently pull off the front cover.
    • The plate on the side should come off.
    • Gently pull off the back cover.
  4. Disassembling Canon PowerShot SD1100 IS Front and Rear Cover: step 4, image 1 of 1
    • The cases should now be removed.
3 other people completed this guide.
Tyler Grossheim
1,524 Reputation
6 Guides authored
Cal Poly, Team 3-32, Regan Winter 2011 Member of Cal Poly, Team 3-32, Regan Winter 2011
CPSU-REGAN-W11S3G32
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 3,468
