Disassembling Nintendo DSi Bottom case
Archived Guide
This guide is retained solely for historical purposes. Use the updated version of the guide to perform your repair.
  1. Careful: steps 1-2 are sourced from a guide that's marked as in-progress.
    Disassembling Nintendo DSi Bottom case, Battery: step 1, image 1 of 1
    • Loosen the two screws on the battery panel. Then lift the panel up to remove it.
  2. Disassembling Nintendo DSi Bottom case: step 2, image 1 of 1
    • L Button.
    • Top of the battery pack.
    • To remove the battery pack, place your fingernail or a spudger at the top of the battery near the L button. Gently lift the battery out.
  3. Careful: steps 3-4 are sourced from a guide that's marked as in-progress.
    Disassembling Nintendo DSi Bottom case, Motherboard: step 3, image 1 of 2 Disassembling Nintendo DSi Bottom case, Motherboard: step 3, image 2 of 2
    • Remove 4 Phillips screws from the board.
    • Lift the main board from the bottom end and flip it over to reveal the last connector.
    • Keep the main board fairly close to the case, making sure not to damage the last ribbon cable holding it in place.
  4. Disassembling Nintendo DSi Bottom case: step 4, image 1 of 1
    • Disconnect the ribbon cable by gently using a plastic opening tool to flip up the black connector latch. The cable should easily slide out from the connector.
    • The motherboard should now be free from the rest of the device.
  5. Disassembling Nintendo DSi Bottom case, Disassembling Nintendo DSi Bottom case: step 5, image 1 of 1
    • Remove the rubber front-panel button membranes from the device. Pay careful attention to where the buttons go, so you can replace them correctly.
    • A/B/X/Y button assembly
    • Select/Start button assembly
    • D-pad
    • Power button
  6. Disassembling Nintendo DSi Bottom case: step 6, image 1 of 2 Disassembling Nintendo DSi Bottom case: step 6, image 2 of 2
    • Remove the plastic buttons and keep them in a safe place.
    • All of the buttons have "key" notches to prevent them from being inserted incorrectly (backwards or in the wrong place), but it can take a while to figure out where everything goes if they get shuffled around.
  7. Disassembling Nintendo DSi Bottom case: step 7, image 1 of 2 Disassembling Nintendo DSi Bottom case: step 7, image 2 of 2
    • Flip the case open, and push the lower screen assembly out of the frame.
rjcamero
50 Reputation
3 Guides authored
Cal Poly, Team 6-1, Maness Fall 2009 Member of Cal Poly, Team 6-1, Maness Fall 2009
CPSU-MANESS-F09S6G1
5 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 5,354
