Disassembling Toshiba T1960CS for HDD Removal
  1. Disassembling Toshiba T1960CS for HDD Removal, HDD Removal: step 1, image 1 of 1
    • Pry up cover, remove screw.
  2. Disassembling Toshiba T1960CS for HDD Removal: step 2, image 1 of 1
    • Remove screws.
  3. Disassembling Toshiba T1960CS for HDD Removal: step 3, image 1 of 1
    • Gently pry out to unsnap top plastic housing.
  4. Disassembling Toshiba T1960CS for HDD Removal: step 4, image 1 of 1
    • Lift keyboard and flip over, but do not remove, it is still attached by ribbon cable.
    • Slide back connector tabs to release ribbon cable.
    • Remove 5 screws and lift out plate to access HDD and FDD.
  5. Disassembling Toshiba T1960CS for HDD Removal: step 5, image 1 of 1
    • To remove HDD loosen tape, lift out BIOS battery, remove screws and slide back HDD housing.
4 other people completed this guide.
WayneG
191 Reputation
1 Guide authored
One Comment
The plastic housing does not come off. It seems to be attached to the screen
James Blimthorpe - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 29
All Time: 3,115
