Dr. Martens Mary Janes Elastic Replacement
  1. Dr. Martens Mary Janes Elastic Replacement, Elastic: step 1, image 1 of 2 Dr. Martens Mary Janes Elastic Replacement, Elastic: step 1, image 2 of 2
    • Remove the buckle from the strap with the broken elastic.
  2. Dr. Martens Mary Janes Elastic Replacement: step 2, image 1 of 1
    • Using a pair of fabric scissors, trim down any frayed elastic on the shoe.
  3. Dr. Martens Mary Janes Elastic Replacement: step 3, image 1 of 1
    • Cut the new elastic to a desired length.
    • Be sure the new elastic is the same dimensions as the existing elastic on the shoe.
  4. Dr. Martens Mary Janes Elastic Replacement: step 4, image 1 of 1
    • Using a sewing pin, pin the new elastic onto the old elastic.
  5. Dr. Martens Mary Janes Elastic Replacement: step 5, image 1 of 1
    • Insert the buckle through the new elastic.
  6. Dr. Martens Mary Janes Elastic Replacement: step 6, image 1 of 3 Dr. Martens Mary Janes Elastic Replacement: step 6, image 2 of 3 Dr. Martens Mary Janes Elastic Replacement: step 6, image 3 of 3
    • Fold down the elastic over the buckle.
    • Cut a small hole with scissors where the prong of the buckle meets the elastic.
    • Put the prong through the hole.
  7. Dr. Martens Mary Janes Elastic Replacement: step 7, image 1 of 1
    • Pull the elastic fully through buckle.
  8. Dr. Martens Mary Janes Elastic Replacement: step 8, image 1 of 2 Dr. Martens Mary Janes Elastic Replacement: step 8, image 2 of 2
    • Pin both sides of the elastic into place on the old elastic.
  9. Dr. Martens Mary Janes Elastic Replacement: step 9, image 1 of 2 Dr. Martens Mary Janes Elastic Replacement: step 9, image 2 of 2
    • Hand sew the elastic into place along the pin.
    • When sewing, be cautious when using a sewing needle.
  10. Dr. Martens Mary Janes Elastic Replacement: step 10, image 1 of 2 Dr. Martens Mary Janes Elastic Replacement: step 10, image 2 of 2
    • Trim down the excess elastic to your desired fit.
  11. Dr. Martens Mary Janes Elastic Replacement: step 11, image 1 of 2 Dr. Martens Mary Janes Elastic Replacement: step 11, image 2 of 2
    • Insert the buckle back into shoe strap.
To reassemble your shoe elastic, follow these instructions in reverse order.
Shu Yin Yu
193 Reputation
1 Guide authored
UC Davis, Team 1-6, Andersen Winter 2024 Member of UC Davis, Team 1-6, Andersen Winter 2024
UCD-ANDERSEN-W24S1G6
3 Members
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 40
All Time: 87
