Dremel 8200 Disassembly
  1. Dremel 8200 Disassembly, Dremel 8200 Disassembly: step 1, image 1 of 2 Dremel 8200 Disassembly, Dremel 8200 Disassembly: step 1, image 2 of 2
    • Take off the screw cap at the top
  2. Dremel 8200 Disassembly: step 2, image 1 of 2 Dremel 8200 Disassembly: step 2, image 2 of 2
    • Take out the battery
    • Remove oblong belt clip
  3. Dremel 8200 Disassembly: step 4, image 1 of 1
    • Unscrew screws
    • Take back u clip out carefully
    • Be very careful to not injure yourself
  4. Dremel 8200 Disassembly: step 6, image 1 of 2 Dremel 8200 Disassembly: step 6, image 2 of 2
    • The casing should just open right up and be easily accessible
  5. Dremel 8200 Disassembly: step 7, image 1 of 1
    • You can remove the buttons except for the sliding one that adjusts the speed
  6. Dremel 8200 Disassembly: step 8, image 1 of 2 Dremel 8200 Disassembly: step 8, image 2 of 2
    • You can take the motor out first and it will be a little hard to do so
    • Work your way down and take out each successive circuit board
    • The last thing to be out should be the sliding speed adjustment and the button for that should fall right out
3 other people completed this guide.
mitchellbarnhart
86 Reputation
1 Guide authored
2 Comments
It will be handy to have either a can of compressed air or an air directional nozzle on your compressor. Be careful of the circuits and small parts that can blow away. You'll be amazed how even with a maintenance schedule, how much dirt will be on the motor fins
m. D. w. - Reply
How do you replace just the bearing in this assembly?
Andre Da Silva - Reply
Past 24 Hours: 2
Past 7 Days: 10
Past 30 Days: 30
All Time: 3,554
