DualSense Controller v2 Middle Trim Replacement
  1. DualSense Controller v2 Middle Trim Replacement, Unclip the right end of the middle trim: step 1, image 1 of 2 DualSense Controller v2 Middle Trim Replacement, Unclip the right end of the middle trim: step 1, image 2 of 2
    • Disconnect and power down your controller before you begin.
    • Insert an opening pick underneath the middle trim at the bottom-right corner of the controller to release the clips securing it to the case.
  2. DualSense Controller v2 Middle Trim Replacement, Unclip the lower-right edge of the middle trim: step 2, image 1 of 3 DualSense Controller v2 Middle Trim Replacement, Unclip the lower-right edge of the middle trim: step 2, image 2 of 3 DualSense Controller v2 Middle Trim Replacement, Unclip the lower-right edge of the middle trim: step 2, image 3 of 3
    • Slide the opening pick along the lower-right edge of the middle trim to release the clips securing it to the case.
  3. DualSense Controller v2 Middle Trim Replacement, Unclip the left end of the middle trim: step 3, image 1 of 2 DualSense Controller v2 Middle Trim Replacement, Unclip the left end of the middle trim: step 3, image 2 of 2
    • Insert an opening pick underneath the middle trim at the bottom-left corner of the controller to release the clips securing it to the case.
  4. DualSense Controller v2 Middle Trim Replacement, Unclip the lower-left edge of the middle trim: step 4, image 1 of 3 DualSense Controller v2 Middle Trim Replacement, Unclip the lower-left edge of the middle trim: step 4, image 2 of 3 DualSense Controller v2 Middle Trim Replacement, Unclip the lower-left edge of the middle trim: step 4, image 3 of 3
    • Slide the opening pick along the lower-left edge of the middle trim to release the clips securing it to the case.
  5. DualSense Controller v2 Middle Trim Replacement, Remove the middle trim: step 5, image 1 of 3 DualSense Controller v2 Middle Trim Replacement, Remove the middle trim: step 5, image 2 of 3 DualSense Controller v2 Middle Trim Replacement, Remove the middle trim: step 5, image 3 of 3
    • Use your fingers to lift up the bottom edge of the middle trim to release the remaining clips.
    • Lift the middle trim over the joysticks to remove it.
    • During reassembly, position the middle trim into place and press along all edges to engage the clips securing it to the controller.
Sam Omiotek
74,330 Reputation
288 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 46
All Time: 498
