DualShock 4 CHU-ZCT2U Charging Assembly Replacement
  1. DualShock 4 CHU-ZCT2U Charging Assembly Replacement, Remove the rear panel screws: step 1, image 1 of 2 DualShock 4 CHU-ZCT2U Charging Assembly Replacement, Remove the rear panel screws: step 1, image 2 of 2
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel.
  2. DualShock 4 CHU-ZCT2U Charging Assembly Replacement, Separate the rear panel: step 2, image 1 of 2 DualShock 4 CHU-ZCT2U Charging Assembly Replacement, Separate the rear panel: step 2, image 2 of 2
    • Four fragile plastic clips hold the panels together. You can see their locations more clearly in this guide.
    • The clips help hold the seams together. If you break these clips, the controller will still work.
    • Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle.
    • Gently pry the rear panel off of the front panel until they become partially separated.
  3. DualShock 4 CHU-ZCT2U Charging Assembly Replacement, Release the plastic clips: step 3, image 1 of 3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement, Release the plastic clips: step 3, image 2 of 3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement, Release the plastic clips: step 3, image 3 of 3
    • Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
  4. DualShock 4 CHU-ZCT2U Charging Assembly Replacement, Remove the rear panel: step 4, image 1 of 2 DualShock 4 CHU-ZCT2U Charging Assembly Replacement, Remove the rear panel: step 4, image 2 of 2
    • Lift the rear panel directly away from the controller.
    • Do not completely remove the rear panel. It is still attached to the controller by a ribbon cable.
  5. DualShock 4 CHU-ZCT2U Charging Assembly Replacement: step 5, image 1 of 2 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Use your fingers to gently pull the ribbon cable straight out of its connector on the motherboard.
    • Since this cable's pull tab is too small to grab with fingers or tweezers, grab the cable itself. Otherwise utilize pull tabs whenever possible.
    • During reassembly, grab the ribbon cable by the blue tab and gently press the cable straight into the connector. Push the blue tab rather than the ribbon cable itself.
  6. DualShock 4 CHU-ZCT2U Charging Assembly Replacement, Remove the light guide: step 6, image 1 of 3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement, Remove the light guide: step 6, image 2 of 3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement, Remove the light guide: step 6, image 3 of 3
    • Use an opening tool or spudger to separate the white plastic bar from the rear panel.
  7. DualShock 4 CHU-ZCT2U Charging Assembly Replacement: step 7, image 1 of 2 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: step 7, image 2 of 2
    • Remove the white plastic bar.
  8. DualShock 4 CHU-ZCT2U Charging Assembly Replacement: step 8, image 1 of 3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: step 8, image 2 of 3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: step 8, image 3 of 3
    • Lift the light guide away from the rear panel to remove it.
    • During reassembly, align the light guide with the rear panel using the notch near the bottom left.
  9. DualShock 4 CHU-ZCT2U Charging Assembly Replacement: step 9, image 1 of 3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: step 9, image 2 of 3 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: step 9, image 3 of 3
    • Use your fingers to press the translucent plastic piece down through the top of the controller.
    • Remove the translucent plastic piece.
  10. DualShock 4 CHU-ZCT2U Charging Assembly Replacement, Remove the charging assembly: step 10, image 1 of 2 DualShock 4 CHU-ZCT2U Charging Assembly Replacement, Remove the charging assembly: step 10, image 2 of 2
    • Use a Phillips screwdriver to remove the 4.4 mm-long screw from the charging assembly.
  11. DualShock 4 CHU-ZCT2U Charging Assembly Replacement: step 11, image 1 of 2 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: step 11, image 2 of 2
    • Use the pointed end of a spudger to lift the charging assembly away from the rear panel.
  12. DualShock 4 CHU-ZCT2U Charging Assembly Replacement: step 12, image 1 of 2 DualShock 4 CHU-ZCT2U Charging Assembly Replacement: step 12, image 2 of 2
    Buy
    • Use your fingers or a pair of tweezers to remove the charging assembly from the rear panel.
7 other people completed this guide.
Sam Omiotek
74,053 Reputation
288 Guides authored
3 Comments
Question:
I have a ps4 controller model CUH-ZCT2U. My charging board model is jds 050.
Can I buy the jds 055 charging board and put that in? Is the jds 050 and the jds 055 charging board interchangeable?
I can't seem to find the jds 050 charging boards anywhere. Only the jds 055. Any help would be very much appreciated. Thanks.
Treadway Customs - Reply
I have not tested the JDS-055 and JDS-050 in a ZCT2U so I cannot guarantee it will work. However, visually they appear to be the same part made by a different manufacturer. I suspect that it will work, but understand that it’s a gamble and make sure the store you buy from has a good return policy like iFixit. If you can wait, add yourself to the notify list for the JDS-050 and order once they become available again.
Sam Omiotek -
Great guide but the correct controller model is CUH-ZCT2U. The title has it as CHU-ZCT2U.
Marco Salvatori - Reply
Past 24 Hours: 24
Past 7 Days: 123
Past 30 Days: 345
All Time: 11,894
