DualShock 4 CHU-ZCT2U Rear Panel Replacement
  1. DualShock 4 CHU-ZCT2U Rear Panel Replacement, Remove the rear panel screws: step 1, image 1 of 2 DualShock 4 CHU-ZCT2U Rear Panel Replacement, Remove the rear panel screws: step 1, image 2 of 2
    • Use a Phillips screwdriver to remove the four 6.4 mm-long screws from the rear panel.
  2. DualShock 4 CHU-ZCT2U Rear Panel Replacement, Separate the rear panel: step 2, image 1 of 2 DualShock 4 CHU-ZCT2U Rear Panel Replacement, Separate the rear panel: step 2, image 2 of 2
    • Four fragile plastic clips hold the panels together. You can see their locations more clearly in this guide.
    • The clips help hold the seams together. If you break these clips, the controller will still work.
    • Insert an opening tool into the crease where the front and rear panel meet, starting from the outside edge of either handle.
    • Gently pry the rear panel off of the front panel until they become partially separated.
  3. DualShock 4 CHU-ZCT2U Rear Panel Replacement, Release the plastic clips: step 3, image 1 of 3 DualShock 4 CHU-ZCT2U Rear Panel Replacement, Release the plastic clips: step 3, image 2 of 3 DualShock 4 CHU-ZCT2U Rear Panel Replacement, Release the plastic clips: step 3, image 3 of 3
    • Use the opening tool to separate the panels by releasing the plastic clips around the perimeter of the controller.
  4. DualShock 4 CHU-ZCT2U Rear Panel Replacement, Remove the rear panel: step 4, image 1 of 2 DualShock 4 CHU-ZCT2U Rear Panel Replacement, Remove the rear panel: step 4, image 2 of 2
    • Lift the rear panel directly away from the controller.
    • Do not completely remove the rear panel. It is still attached to the controller by a ribbon cable.
  5. DualShock 4 CHU-ZCT2U Rear Panel Replacement: step 5, image 1 of 2 DualShock 4 CHU-ZCT2U Rear Panel Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Use your fingers to gently pull the ribbon cable straight out of its connector on the motherboard.
    • Since this cable's pull tab is too small to grab with fingers or tweezers, grab the cable itself. Otherwise utilize pull tabs whenever possible.
    • During reassembly, grab the ribbon cable by the blue tab and gently press the cable straight into the connector. Push the blue tab rather than the ribbon cable itself.
2 other people completed this guide.
Sam Omiotek
74,053 Reputation
288 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 44
Past 30 Days: 109
All Time: 2,772
