DualShock 4 CUH-ZCT1 Charging Port Replacement
  1. DualShock 4 CUH-ZCT1 Charging Port Replacement, Charging Port: step 1, image 1 of 1
    • Flip the Dualshock 4 controller on its back, and use a Phillips #00 screwdriver to remove the four 6 mm screws.
  2. DualShock 4 CUH-ZCT1 Charging Port Replacement: step 2, image 1 of 1
    • Slowly lift the backplate onto the front side of the controller making sure not to fully remove the backplate.
  3. DualShock 4 CUH-ZCT1 Charging Port Replacement: step 3, image 1 of 2 DualShock 4 CUH-ZCT1 Charging Port Replacement: step 3, image 2 of 2
    • Remove the ribbon cable from the motherboard of the controller and place the top half of the controller on the side for later.
  4. DualShock 4 CUH-ZCT1 Charging Port Replacement: step 4, image 1 of 1
    • Remove the light bar's sub-assembly by gently lifting up the piece.
  5. DualShock 4 CUH-ZCT1 Charging Port Replacement: step 5, image 1 of 1
    • Lift the clear plastic piece out of the controller by pulling into the controller and removing it.
  6. DualShock 4 CUH-ZCT1 Charging Port Replacement: step 6, image 1 of 1
    • Remove the two 6 mm Phillips screws that are on top of the PCB of the charging port.
  7. DualShock 4 CUH-ZCT1 Charging Port Replacement: step 7, image 1 of 2 DualShock 4 CUH-ZCT1 Charging Port Replacement: step 7, image 2 of 2
    • Gently wiggle the charging port's PCB side to side until it detaches from the controller.
7 other people completed this guide.
Andy Lam
307 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 23
Past 7 Days: 168
Past 30 Days: 365
All Time: 3,520
