Electric Lint Remover Blade Replacement
  1. Electric Lint Remover Blade Replacement, Blade: step 1, image 1 of 2 Electric Lint Remover Blade Replacement, Blade: step 1, image 2 of 2
    • Remove the lint container by sliding to the right until it clicks off.
    • Remove any lint from the lint container for a clean process.
  2. Electric Lint Remover Blade Replacement: step 2, image 1 of 3 Electric Lint Remover Blade Replacement: step 2, image 2 of 3 Electric Lint Remover Blade Replacement: step 2, image 3 of 3
    • Rotate the perforated cap counterclockwise until it can be removed.
  3. Electric Lint Remover Blade Replacement: step 3, image 1 of 2 Electric Lint Remover Blade Replacement: step 3, image 2 of 2
    • Use your flathead screwdriver to get in between the device and the blades.
    • Push the plastic blade holder outward from the device until it pops off.
  4. Electric Lint Remover Blade Replacement: step 4, image 1 of 2 Electric Lint Remover Blade Replacement: step 4, image 2 of 2
    • Lift the wire out of the defective blade's hole, using the flathead screwdriver.
  5. Electric Lint Remover Blade Replacement: step 5, image 1 of 3 Electric Lint Remover Blade Replacement: step 5, image 2 of 3 Electric Lint Remover Blade Replacement: step 5, image 3 of 3
    • Insert the replacement blade into the empty slot.
    • Caution: pinching the replacement blade from surface may result in injury.
  6. Electric Lint Remover Blade Replacement: step 6, image 1 of 2 Electric Lint Remover Blade Replacement: step 6, image 2 of 2
    • Flip the cap onto its backside and firmly hold down the side with the loose blade.
    • Pull back the wire using your fingers, and insert wire back into the blade hole.
  7. Electric Lint Remover Blade Replacement: step 7, image 1 of 3 Electric Lint Remover Blade Replacement: step 7, image 2 of 3 Electric Lint Remover Blade Replacement: step 7, image 3 of 3
    • Insert the plastic blade holder back on the shaft of the device, by aligning the hexagonal hole on the cap with the shaft.
    • Press down gently on the plastic blade cap.
    • Caution: Make sure to press on the cap and not on the blades, otherwise action may cause injury.
  8. Electric Lint Remover Blade Replacement: step 8, image 1 of 2 Electric Lint Remover Blade Replacement: step 8, image 2 of 2
    • Place perforated cap on top of the blade cap and turn clockwise until tight.
  9. Electric Lint Remover Blade Replacement: step 9, image 1 of 2 Electric Lint Remover Blade Replacement: step 9, image 2 of 2
    • Slide the lint container to the left and press until it clicks into place.
We hope this guide helped you. Happy Fixing!
Chris Koenig
169 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 29
All Time: 190
