Electric dryer defective drive belt Replacement
  1. Electric dryer defective drive belt Replacement, Defective Drive Belt: step 1, image 1 of 1
    • There are many brands of electric dryers out there, but fortunately their construction follows just a few basic designs. The one I'm describing is a 20 year old Canadian Eaton model, but some of the inexpensive models sold today have the same construction.
    • A good indicator that you are dealing with a similar model is the presence of three screws at the end of the drum, which you can see after opening the appliance door. In these appliances the drum is held in place by the axis connected by the three screws you can see in the picture and the friction pads at the front panel of the dryer.
    • The first thing you will want to do is reach behind the dryer and unplug it from the electric outlet.
  2. Electric dryer defective drive belt Replacement: step 2, image 1 of 2 Electric dryer defective drive belt Replacement: step 2, image 2 of 2
    • If the belt is not yet completely broken, you will need to disengage it from the motor an the tensioner. To do that, unscrew the service door at the back.
    • Inside the door you will see the drive belt, wrapped around the motor pulley and the tensioner. Reach inside the appliance, push down on the tensioner lever, and disengage the belt. Be careful not to cut yourself: there are sharp metal edges all around.
5 other people completed this guide.
Nick Ivanov
2,263 Reputation
3 Guides authored
2 Comments
Just what I needed - now I have to get a new belt. Thanks for the info...
fmorgan - Reply
Update from previous comment - for fitting the new belt https://www.youtube.com/watch?v=4M1x0luY...
fmorgan - Reply
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 35
All Time: 4,541
