FAO Schwarz Apex 1 Front Axle Replacement
  1. FAO Schwarz Apex 1 Front Axle Replacement, Wheel: step 1, image 1 of 3 FAO Schwarz Apex 1 Front Axle Replacement, Wheel: step 1, image 2 of 3 FAO Schwarz Apex 1 Front Axle Replacement, Wheel: step 1, image 3 of 3
    • Position device so that the wheels are on a firm surface .
    • Using a J1 Screwdriver bit, remove the 11 mm screw from the center of the wheel.
  2. FAO Schwarz Apex 1 Front Axle Replacement: step 2, image 1 of 1
    • After removing the 11 mm screw, firmly grip the wheel and pull away from the vehicle.
  3. FAO Schwarz Apex 1 Front Axle Replacement, Front Wheel Springs: step 3, image 1 of 2 FAO Schwarz Apex 1 Front Axle Replacement, Front Wheel Springs: step 3, image 2 of 2
    • Position device upside down so that the screws on the plastic axle pieces can be removed.
    • Use J1 screwdriver bit to remove two 10 mm screws to remove the plastic axle pieces to make access to the telescopic piston easier.
  4. FAO Schwarz Apex 1 Front Axle Replacement: step 4, image 1 of 1
    • Secure a firm grip on the spring and telescopic piston.
    • Pull telescopic piston holding the spring off the device (this may be difficult).
  5. FAO Schwarz Apex 1 Front Axle Replacement: step 5, image 1 of 1
    • Using a tool such as a spudger, gradually maneuver spring off of telescopic piston.
  6. FAO Schwarz Apex 1 Front Axle Replacement, Front Axle: step 6, image 1 of 3 FAO Schwarz Apex 1 Front Axle Replacement, Front Axle: step 6, image 2 of 3 FAO Schwarz Apex 1 Front Axle Replacement, Front Axle: step 6, image 3 of 3
    • Carefully turn the vehicle over so that the bottom side is facing upward.
    • Using a J1 Screwdriver bit, remove the two 10 mm screws that secure the wheel bearing.
    • Pull the plastic piece that secures the wheel bearing off of the axle.
  7. FAO Schwarz Apex 1 Front Axle Replacement: step 7, image 1 of 2 FAO Schwarz Apex 1 Front Axle Replacement: step 7, image 2 of 2
    • Position the axle entirely upright before lifting away from the vehicle.
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 271
