FRIGIDARE FFHT1514TW0 Refrigerator Light Bulb Replacement
  1. FRIGIDARE FFHT1514TW0 Refrigerator Light Bulb Replacement, Light Bulb: step 1, image 1 of 3 FRIGIDARE FFHT1514TW0 Refrigerator Light Bulb Replacement, Light Bulb: step 1, image 2 of 3 FRIGIDARE FFHT1514TW0 Refrigerator Light Bulb Replacement, Light Bulb: step 1, image 3 of 3
    • Lift the shelf right below the light bulb area by lifting the hooks off the side and sliding it out so you have space to do your repair.
  2. FRIGIDARE FFHT1514TW0 Refrigerator Light Bulb Replacement: step 2, image 1 of 2 FRIGIDARE FFHT1514TW0 Refrigerator Light Bulb Replacement: step 2, image 2 of 2
    • Assess the area of the light bulb to see how much space you have to do your replacement since it usually a tight space.
  3. FRIGIDARE FFHT1514TW0 Refrigerator Light Bulb Replacement: step 3, image 1 of 1
    • Put on some gloves to avoid getting cut in case the light bulb breaks from the pressure put on it.
  4. FRIGIDARE FFHT1514TW0 Refrigerator Light Bulb Replacement: step 4, image 1 of 1
    • For safety reasons put a bin right below the area of the light bulb just in case the light bulb breaks.
  5. FRIGIDARE FFHT1514TW0 Refrigerator Light Bulb Replacement: step 5, image 1 of 3 FRIGIDARE FFHT1514TW0 Refrigerator Light Bulb Replacement: step 5, image 2 of 3 FRIGIDARE FFHT1514TW0 Refrigerator Light Bulb Replacement: step 5, image 3 of 3
    • Unscrew the light bulb by twisting it counter clockwise.
    • Don't press too hard as the light bulb is fragile.
  6. FRIGIDARE FFHT1514TW0 Refrigerator Light Bulb Replacement: step 6, image 1 of 3 FRIGIDARE FFHT1514TW0 Refrigerator Light Bulb Replacement: step 6, image 2 of 3 FRIGIDARE FFHT1514TW0 Refrigerator Light Bulb Replacement: step 6, image 3 of 3
    • Replace the bulb.
  7. FRIGIDARE FFHT1514TW0 Refrigerator Light Bulb Replacement: step 7, image 1 of 2 FRIGIDARE FFHT1514TW0 Refrigerator Light Bulb Replacement: step 7, image 2 of 2
    • To make sure the light bulb works and was fitted correctly close the door and open it to see if the light turns on and if it doesn’t redo steps 6-9.
Finish Line
Mirza Baig
145 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 25
All Time: 109
