Fairphone 4 Battery Replacement
  1. Fairphone 4 Battery Replacement, Pry the back cover up: step 1, image 1 of 2 Fairphone 4 Battery Replacement, Pry the back cover up: step 1, image 2 of 2
    • Be sure to power off your phone before you begin.
    • Insert your thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
    • Pry the back cover up to start separating its plastic clips.
  2. Fairphone 4 Battery Replacement: step 2, image 1 of 3 Fairphone 4 Battery Replacement: step 2, image 2 of 3 Fairphone 4 Battery Replacement: step 2, image 3 of 3
    • Using your thumbnail or an opening pick, slide along the right side of the phone to loosen the plastic clips.
  3. Fairphone 4 Battery Replacement: step 3, image 1 of 3 Fairphone 4 Battery Replacement: step 3, image 2 of 3 Fairphone 4 Battery Replacement: step 3, image 3 of 3
    • Slide along the bottom of the phone to loosen the plastic clips.
  4. Fairphone 4 Battery Replacement: step 4, image 1 of 3 Fairphone 4 Battery Replacement: step 4, image 2 of 3 Fairphone 4 Battery Replacement: step 4, image 3 of 3
    • Slide along the left side of the phone to loosen the plastic clips.
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • To reinstall the back cover press it firmly into place until you hear a snap from the plastic clips.
  5. Fairphone 4 Battery Replacement, Lever up the Battery: step 5, image 1 of 3 Fairphone 4 Battery Replacement, Lever up the Battery: step 5, image 2 of 3 Fairphone 4 Battery Replacement, Lever up the Battery: step 5, image 3 of 3
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    • Lift the battery out of its recess and remove it.
    • Remove the battery.
For optimal performance, calibrate your newly installed battery after completing this guide.
5 other people completed this guide.
Manuel Haeussermann
15,619 Reputation
71 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,432 Guides authored
One Comment
I am not sure steps 2,3,4 are really necessary in this guide.
Bartłomiej Tokarzewski - Reply
Past 24 Hours: 3
Past 7 Days: 42
Past 30 Days: 178
All Time: 6,830
