Fairphone 4 Front Camera Replacement
  1. Fairphone 4 Front Camera Replacement, Pry the back cover up: step 1, image 1 of 2 Fairphone 4 Front Camera Replacement, Pry the back cover up: step 1, image 2 of 2
    • Be sure to power off your phone before you begin.
    • Insert your thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
    • Pry the back cover up to start separating its plastic clips.
  2. Fairphone 4 Front Camera Replacement: step 2, image 1 of 3 Fairphone 4 Front Camera Replacement: step 2, image 2 of 3 Fairphone 4 Front Camera Replacement: step 2, image 3 of 3
    • Using your thumbnail or an opening pick, slide along the right side of the phone to loosen the plastic clips.
  3. Fairphone 4 Front Camera Replacement: step 3, image 1 of 3 Fairphone 4 Front Camera Replacement: step 3, image 2 of 3 Fairphone 4 Front Camera Replacement: step 3, image 3 of 3
    • Slide along the bottom of the phone to loosen the plastic clips.
  4. Fairphone 4 Front Camera Replacement: step 4, image 1 of 3 Fairphone 4 Front Camera Replacement: step 4, image 2 of 3 Fairphone 4 Front Camera Replacement: step 4, image 3 of 3
    • Slide along the left side of the phone to loosen the plastic clips.
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • To reinstall the back cover press it firmly into place until you hear a snap from the plastic clips.
  5. Fairphone 4 Front Camera Replacement, Lever up the Battery: step 5, image 1 of 3 Fairphone 4 Front Camera Replacement, Lever up the Battery: step 5, image 2 of 3 Fairphone 4 Front Camera Replacement, Lever up the Battery: step 5, image 3 of 3
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    • Lift the battery out of its recess and remove it.
    • Remove the battery.
  6. Fairphone 4 Front Camera Replacement, Unscrew the cable cover: step 6, image 1 of 1
    • Remove the 4.8 mm-long Phillips screw.
  7. Fairphone 4 Front Camera Replacement, Remove the cable cover: step 7, image 1 of 2 Fairphone 4 Front Camera Replacement, Remove the cable cover: step 7, image 2 of 2
    • Insert an opening pick beneath the cover near the triangular mark.
    • Twist the opening pick to pry the cover up.
    • Remove the cover.
  8. Fairphone 4 Front Camera Replacement, Disconnect cables: step 8, image 1 of 3 Fairphone 4 Front Camera Replacement, Disconnect cables: step 8, image 2 of 3 Fairphone 4 Front Camera Replacement, Disconnect cables: step 8, image 3 of 3
    • Use a spudger or an opening pick to pry up and disconnect the two camera connection cables.
  9. Fairphone 4 Front Camera Replacement: step 9, image 1 of 3 Fairphone 4 Front Camera Replacement: step 9, image 2 of 3 Fairphone 4 Front Camera Replacement: step 9, image 3 of 3
    • Lift up the right connector to reveal the additional connector beneath it.
    • Use a spudger or an opening pick to pry up and disconnect the third camera connection cable.
  10. Fairphone 4 Front Camera Replacement, Unscrew the rear camera module: step 10, image 1 of 1
    • Remove the five 4.8 mm-long Phillips screws.
  11. Fairphone 4 Front Camera Replacement: step 11, image 1 of 3 Fairphone 4 Front Camera Replacement: step 11, image 2 of 3 Fairphone 4 Front Camera Replacement: step 11, image 3 of 3
    • Use an opening pick to slide underneath the rear camera module.
    • Slide the opening pick along the rear camera module to release the clips that hold it in place.
  12. Fairphone 4 Front Camera Replacement: step 12, image 1 of 1
    • Lift the rear camera module and remove it.
  13. Fairphone 4 Front Camera Replacement, Disconnect the front camera cable: step 13, image 1 of 2 Fairphone 4 Front Camera Replacement, Disconnect the front camera cable: step 13, image 2 of 2
    • Use an opening pick to pry up and disconnect the front camera cable.
  14. Fairphone 4 Front Camera Replacement, Lift out the front camera: step 14, image 1 of 2 Fairphone 4 Front Camera Replacement, Lift out the front camera: step 14, image 2 of 2
    • Use an opening pick to lift out the front camera by carefully pulling it away from the frame so it pops out of its recess.
    • Alternatively you can turn the phone over to let gravity to do its part.
  15. Fairphone 4 Front Camera Replacement, Remove the front camera: step 15, image 1 of 1
    • Grab the front camera and remove it.
Manuel Haeussermann
15,619 Reputation
71 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,439 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 52
All Time: 1,203
