Fitbit Alta HR Battery Replacement
  1. Fitbit Alta HR Battery Replacement, Remove straps: step 1, image 1 of 2 Fitbit Alta HR Battery Replacement, Remove straps: step 1, image 2 of 2
    • Push in the clip and slide off the strap from each side.
  2. Fitbit Alta HR Battery Replacement, Remove front cover: step 2, image 1 of 1
    • Use a spudger to remove the front cover.
  3. Fitbit Alta HR Battery Replacement, Lift display: step 3, image 1 of 1
    • Use a spudger to lift the display.
  4. Fitbit Alta HR Battery Replacement, Disconnect heart rate monitor: step 4, image 1 of 1
    • Use a spudger to disconnect the cable that connects the heart rate monitor to the motherboard.
  5. Fitbit Alta HR Battery Replacement, Remove screws from motherboard: step 5, image 1 of 1
    • Use a hex 0.7 screwdriver to remove the screws from the motherboard.
  6. Fitbit Alta HR Battery Replacement, Lift motherboard: step 6, image 1 of 2 Fitbit Alta HR Battery Replacement, Lift motherboard: step 6, image 2 of 2
    • Use a spudger to lift the motherboard.
  7. Fitbit Alta HR Battery Replacement, Lift battery and remove innards: step 7, image 1 of 1
    • Use a spudger to lift the battery.
    • When the battery is lifted, the connected components (display, motherboard, battery) will come out.
    • Use a soldering iron to desolder the two battery contacts from the motherboard.
    • Ensure positive and negative wires are in the correct positions. There are + and – signs on the motherboard. Red is positive. Black is negative.
    • Use a soldering iron and lead-free solder to solder the new battery to the motherboard.
3 other people completed this guide.
Wendy Sato
229 Reputation
1 Guide authored
One Comment
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 73
All Time: 1,787
