Fujitsu Lifebook Stylistic Q584 Battery Replacement
  1. Fujitsu Lifebook Stylistic Q584 Battery  Replacement, Back Case: step 1, image 1 of 1
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: step 2, image 1 of 1
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: step 3, image 1 of 1
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 Battery  Replacement, Inner Back Shield: step 4, image 1 of 1
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: step 5, image 1 of 1
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: step 6, image 1 of 1
  7. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: step 7, image 1 of 1
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
  8. Fujitsu Lifebook Stylistic Q584 Battery  Replacement, Battery: step 8, image 1 of 1
    • Pull up the cord that connects the battery to the motherboard
  9. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: step 9, image 1 of 1
    • Remove seven 1mm screws using a PH00 screwdriver.
  10. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: step 10, image 1 of 1
    • Disconnect upper peripheral ribbons from motherboard.
    • Disconnect left peripheral ribbon from motherboard.
  11. Fujitsu Lifebook Stylistic Q584 Battery  Replacement: step 11, image 1 of 1
    • Gently lift the battery from the casing.
Connor Stanton
613 Reputation
6 Guides authored
One Comment
I have flickering video problems after a drop, its probably video cable loose. Where is the video cable, To try reseating.
Vince - Reply
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 40
All Time: 2,992
