Fujitsu Lifebook Stylistic Q584 Camera Replacement
  1. Fujitsu Lifebook Stylistic Q584 Camera Replacement, Back Case: step 1, image 1 of 1
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Camera Replacement: step 2, image 1 of 1
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Camera Replacement: step 3, image 1 of 1
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 Camera Replacement, Inner Back Shield: step 4, image 1 of 1
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 Camera Replacement: step 5, image 1 of 1
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 Camera Replacement: step 6, image 1 of 1
  7. Fujitsu Lifebook Stylistic Q584 Camera Replacement: step 7, image 1 of 1
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
  8. Fujitsu Lifebook Stylistic Q584 Camera Replacement, Camera: step 8, image 1 of 2 Fujitsu Lifebook Stylistic Q584 Camera Replacement, Camera: step 8, image 2 of 2
    • Pull up the cord that connects the battery to the motherboard
  9. Fujitsu Lifebook Stylistic Q584 Camera Replacement: step 9, image 1 of 2 Fujitsu Lifebook Stylistic Q584 Camera Replacement: step 9, image 2 of 2
    • Pull the ribbon straight up from the back of the camera board
  10. Fujitsu Lifebook Stylistic Q584 Camera Replacement: step 10, image 1 of 1
    • Remove the single 2mm screw using a PH000 screwdriver from the camera board.
Connor Stanton
613 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 11
All Time: 300
