Fujitsu Lifebook Stylistic Q584 Motherboard Replacement
  1. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement, Back Case: step 1, image 1 of 1
    • Remove the white sticker covering the screws (if applicable).
    • Use the PH1 screwdriver to remove the four 2 mm screws from the the backside of the device.
  2. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: step 2, image 1 of 1
    • Insert the plastic opening tool along the seam of the back case.
    • Gently slide the plastic opening tool along the entire seam popping the clips free.
  3. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: step 3, image 1 of 1
    • Carefully lift the back case and remove the smartcard ribbon from the motherboard.
  4. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement, Inner Back Shield: step 4, image 1 of 1
    • Remove the ten 3mm screws with a PH00 screwdriver from the shield.
  5. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: step 5, image 1 of 1
    • Remove the grey docking station port cover.
  6. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: step 6, image 1 of 1
  7. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: step 7, image 1 of 1
    • Lift the shield away from the device and remove the fingerprint scanner's ribbon from the motherboard.
  8. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement, Battery: step 8, image 1 of 1
    • Pull up the cord that connects the battery to the motherboard
  9. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: step 9, image 1 of 1
    • Remove seven 1mm screws using a PH00 screwdriver.
  10. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: step 10, image 1 of 1
    • Disconnect upper peripheral ribbons from motherboard.
    • Disconnect left peripheral ribbon from motherboard.
  11. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: step 11, image 1 of 1
    • Gently lift the battery from the casing.
  12. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement, Motherboard: step 12, image 1 of 1
    • Remove three 3mm screws using a PH00 screwdriver.
  13. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: step 13, image 1 of 1
    • Remove all of the ribbon connector cables from the motherboard using an ESD-safe spudger.
  14. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: step 14, image 1 of 1
    • Gently pry up the motherboard.
  15. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: step 15, image 1 of 1
    • Gently lift the foil tape under the motherboard to reveal the connector.
  16. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: step 16, image 1 of 3 Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: step 16, image 2 of 3 Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: step 16, image 3 of 3
    • Remove the clip holding in the connector with an ESD-safe spudger.
  17. Fujitsu Lifebook Stylistic Q584 Motherboard Replacement: step 17, image 1 of 1
    • Remove the connector with an ESD-safe spudger.
3 other people completed this guide.
Casey
280 Reputation
2 Guides authored
IUPUI, Team S1-G1, Henning Spring 2019 Member of IUPUI, Team S1-G1, Henning Spring 2019
IUPUI-HENNING-S19S1G1
3 Members
3 Guides authored
One Comment
step16, that metal clip is supposed to be lifted up, not departed away
net ho - Reply
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 26
All Time: 1,434
