GoPro Hero3+ Silver Edition Front Panel Replacement
  1. GoPro Hero3+ Silver Edition Front Panel Replacement, Front Panel: step 1, image 1 of 1
    • Insert a plastic opening tool in between the front face plate and the black housing.
    • Make sure you insert the plastic opening tool next to the microSD card slot. There is a small gap that will help separate the face plate.
  2. GoPro Hero3+ Silver Edition Front Panel Replacement: step 2, image 1 of 1
    • Continue to use the plastic opening tool and separate the front face plate from the rest of the device.
    • There is adhesive that helps attach the front face plate. Some extra prying may be required to separate the face plate, but do not use excessive force.
4 other people completed this guide.
Patrick Cook
687 Reputation
3 Guides authored
Cal Poly, Team 5-8, Maness Fall 2015 Member of Cal Poly, Team 5-8, Maness Fall 2015
CPSU-MANESS-F15S5G8
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 8
All Time: 582
