Golf Club Shaft Replacement
  1. Golf Club Shaft Replacement, Shaft: step 1, image 1 of 1
    • Use a heat gun to melt the old epoxy holding the club head to the old shaft.
    • Caution: Heat guns can get very hot, so use caution when handling them.
  2. Golf Club Shaft Replacement: step 2, image 1 of 3 Golf Club Shaft Replacement: step 2, image 2 of 3 Golf Club Shaft Replacement: step 2, image 3 of 3
    • Stabilize the club shaft using a vise grip or the weight of a friend.
    • With a pair of oven mitts, remove the club head by carefully twisting it from the shaft.
  3. Golf Club Shaft Replacement: step 3, image 1 of 2 Golf Club Shaft Replacement: step 3, image 2 of 2
    • Clean out the inside of the club head with acetone and a small wire brush.
    • Cleaning the club head will make applying the new epoxy effective.
  4. Golf Club Shaft Replacement: step 4, image 1 of 1
    • Place the cleaned club head on the new shaft and mark the where the end of the club head reaches on the shaft.
    • Remove the club head.
  5. Golf Club Shaft Replacement: step 5, image 1 of 3 Golf Club Shaft Replacement: step 5, image 2 of 3 Golf Club Shaft Replacement: step 5, image 3 of 3
    • Take some sand paper and sand the shaft past your mark leading to the tip.
    • A good technique is to wrap the sandpaper around the tip while twisting the hand holding the sandpaper back and forth.
  6. Golf Club Shaft Replacement: step 6, image 1 of 3 Golf Club Shaft Replacement: step 6, image 2 of 3 Golf Club Shaft Replacement: step 6, image 3 of 3
    • Get the epoxy ready by pouring it into a plate.
    • Use a toothpick to apply epoxy into the part of the club head that goes over the shaft.
  7. Golf Club Shaft Replacement: step 7, image 1 of 3 Golf Club Shaft Replacement: step 7, image 2 of 3 Golf Club Shaft Replacement: step 7, image 3 of 3
    • Slide the new shaft into the club head.
    • Wipe off the excess epoxy that squeezes out.
    • Let the epoxy set overnight for an optimal seal, then it will be ready for use.
Finish Line
George Bassili
166 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 68
All Time: 1,263
