Google Pixel 6 Fingerprint Reader Replacement
  1. Google Pixel 6 Fingerprint Reader Replacement, Safety precautions: step 1, image 1 of 2 Google Pixel 6 Fingerprint Reader Replacement, Safety precautions: step 1, image 2 of 2
    • Allow your battery to drain below 25% before starting this repair. A charged battery may catch fire if damaged.
    • Fully power off your phone and unplug any cables.
  2. Google Pixel 6 Fingerprint Reader Replacement, Anti-Clamp instructions: step 2, image 1 of 3 Google Pixel 6 Fingerprint Reader Replacement, Anti-Clamp instructions: step 2, image 2 of 3 Google Pixel 6 Fingerprint Reader Replacement, Anti-Clamp instructions: step 2, image 3 of 3
    Tool used on this step:
    Clampy - Anti-Clamp
    $24.95
    Buy
    • The next three steps demonstrate the Anti-Clamp, a tool we designed to make the opening procedure easier. If you aren't using the Anti-Clamp, skip down three steps for an alternate method.
    • For complete instructions on how to use the Anti-Clamp, check out this guide.
    • If your screen is cracked, cover it with a layer of clear packing tape to help the suction cup adhere.
    • Pull the blue handle backwards to unlock the Anti-Clamp's arms.
    • Slide the arms over either the left or right edge of your phone.
    • Position the suction cups near the bottom edge of the phone—one on the front, and one on the back.
    • Squeeze the cups together to apply suction.
    • If you find that the surface of your phone is too slippery for the Anti-Clamp to hold onto, you can use tape to create a grippier surface.
  3. Google Pixel 6 Fingerprint Reader Replacement: step 3, image 1 of 3 Google Pixel 6 Fingerprint Reader Replacement: step 3, image 2 of 3 Google Pixel 6 Fingerprint Reader Replacement: step 3, image 3 of 3
    • Pull the blue handle forward to lock the arms.
    • Turn the handle clockwise 360 degrees or until the cups start to stretch.
    • Make sure the suction cups remain aligned with each other. If they begin to slip out of alignment, loosen the suction cups slightly and realign the arms.
  4. Google Pixel 6 Fingerprint Reader Replacement: step 4, image 1 of 3 Google Pixel 6 Fingerprint Reader Replacement: step 4, image 2 of 3 Google Pixel 6 Fingerprint Reader Replacement: step 4, image 3 of 3
    • Heat an iOpener and thread it through the arms of the Anti-Clamp.
    • You can also use a hair dryer or heat gun—but extreme heat can damage the display and/or internal battery, so proceed with care.
    • Fold the iOpener so it lays on the bottom edge of the phone.
    • Wait one minute to give the adhesive a chance to release and present an opening gap.
    • Insert an opening pick under the screen frame when the Anti-Clamp creates a large enough gap.
    • If the Anti-Clamp doesn't create a sufficient gap, apply more heat to the area and rotate the handle clockwise half a turn.
    • Don't crank more than a half a turn at a time, and wait one minute between turns. Let the Anti-Clamp and time do the work for you.
    • Skip the next two steps.
  5. Google Pixel 6 Fingerprint Reader Replacement, Loosen the display adhesive: step 5, image 1 of 1
    • Apply a heated iOpener to the screen to loosen the adhesive underneath. Apply the iOpener for at least three minutes.
    • A hair dryer, heat gun, or hot plate may also be used, but be careful not to overheat the device.
  6. Google Pixel 6 Fingerprint Reader Replacement, Insert an opening pick: step 6, image 1 of 3 Google Pixel 6 Fingerprint Reader Replacement, Insert an opening pick: step 6, image 2 of 3 Google Pixel 6 Fingerprint Reader Replacement, Insert an opening pick: step 6, image 3 of 3
    • Once the screen is warm to the touch, apply a suction handle to the bottom edge of the screen.
    • If your screen is badly cracked, covering it with a layer of clear packing tape may allow the suction handle to adhere. Alternatively, very strong tape may be used instead of the suction handle. If all else fails, you can superglue the suction handle to the screen.
    • Lift the screen, including its safety frame, with the suction handle to create a small gap between the screen and the phone assembly.
    • Insert an opening pick into the gap between the screen frame and the phone assembly.
    • Make sure to insert your opening pick in the right position to avoid separating the screen from its safety frame instead of the phone assembly.
    • Slide the opening pick to the bottom right corner of the screen to slice its adhesive.
    • Leave the opening pick in place to prevent the adhesive from resealing.
  7. Google Pixel 6 Fingerprint Reader Replacement, Slice the adhesive: step 7, image 1 of 2 Google Pixel 6 Fingerprint Reader Replacement, Slice the adhesive: step 7, image 2 of 2
    • Insert a second opening pick at the bottom edge and slide it to the bottom left corner of the screen to slice the adhesive.
  8. Google Pixel 6 Fingerprint Reader Replacement: step 8, image 1 of 3 Google Pixel 6 Fingerprint Reader Replacement: step 8, image 2 of 3 Google Pixel 6 Fingerprint Reader Replacement: step 8, image 3 of 3
    • The screen of the Google Pixel 6 is not only held in place by adhesive but also small plastic clips. If your opening pick gets blocked during the screen removal procedure, it means you inserted your pick too deep underneath the screen. Only insert the tip of the opening pick (3-4 mm) when slicing the display adhesive.
    • Insert a third opening pick underneath the bottom left corner of the screen.
    • Slide the opening pick along the left edge of the screen to slice the adhesive.
    • Leave the opening pick in the top left corner to prevent the adhesive from resealing.
  9. Google Pixel 6 Fingerprint Reader Replacement: step 9, image 1 of 3 Google Pixel 6 Fingerprint Reader Replacement: step 9, image 2 of 3 Google Pixel 6 Fingerprint Reader Replacement: step 9, image 3 of 3
    • If the adhesive becomes hard to cut, it has most likely cooled down. Use your iOpener or heat gun for 1-2 minutes to reheat it.
    • When you slice near the front facing camera, insert only the tip of the opening pick (2-3 mm) to avoid damaging or smearing the camera.
    • Insert a fourth opening pick at the top left corner of the screen.
    • Slide the opening pick along the top edge of the phone to slice the adhesive.
    • Leave the opening pick in the top right corner to prevent the adhesive from resealing.
  10. Google Pixel 6 Fingerprint Reader Replacement: step 10, image 1 of 2 Google Pixel 6 Fingerprint Reader Replacement: step 10, image 2 of 2
    • Insert a fifth opening pick and slide it along the right edge of the phone to slice the remaining adhesive.
    • Do not try to remove the display all the way yet, the screen is still connected to the phone assembly.
  11. Google Pixel 6 Fingerprint Reader Replacement, Open up the phone assembly: step 11, image 1 of 3 Google Pixel 6 Fingerprint Reader Replacement, Open up the phone assembly: step 11, image 2 of 3 Google Pixel 6 Fingerprint Reader Replacement, Open up the phone assembly: step 11, image 3 of 3
    • Avoid straining the display cable during the following procedure.
    • Carefully open the right side of the screen to the left side of the phone assembly like you would open a book.
  12. Google Pixel 6 Fingerprint Reader Replacement, Remove the display cable bracket: step 12, image 1 of 3 Google Pixel 6 Fingerprint Reader Replacement, Remove the display cable bracket: step 12, image 2 of 3 Google Pixel 6 Fingerprint Reader Replacement, Remove the display cable bracket: step 12, image 3 of 3
    Buy
    • Use a pair of tweezers to carefully unhinge and remove the metal bracket sitting on top of the display cable connector.
    • Make sure to keep this component to reinstall it during reassembly.
  13. Google Pixel 6 Fingerprint Reader Replacement, Disconnect the display cable: step 13, image 1 of 2 Google Pixel 6 Fingerprint Reader Replacement, Disconnect the display cable: step 13, image 2 of 2
    • Use a spudger to disconnect the display flex cable by prying the connector straight up from its socket.
  14. Google Pixel 6 Fingerprint Reader Replacement, Remove the screen: step 14, image 1 of 1
    • Remove the screen.
    • During reassembly:
    • If you replaced the screen, check the front-facing camera hole on the screen and remove any remaining protective liners in it.
    • Remember to reinstall the display cable bracket.
    • This is a good point to test your phone before sealing it up. Temporarily connect your screen, power on your phone, and make sure it works as expected. Before continuing with reassembly, power off your phone and disconnect the screen.
    • Follow this guide if you're using custom-cut adhesives for your device.
    • Follow this guide if you're using a pre-cut adhesive card.
    • If you're installing a new screen, follow this guide to calibrate the fingerprint sensor.
  15. Google Pixel 6 Fingerprint Reader Replacement, Open the ZIF connector: step 15, image 1 of 2 Google Pixel 6 Fingerprint Reader Replacement, Open the ZIF connector: step 15, image 2 of 2
    Buy
    • If you replace the fingerprint reader in the Pixel 6 or switch it between two different displays you need recalibrate it to maintain its functionality.
    • Use one arm of a pair of tweezers to carefully open the ZIF connector at the rear side of the screen.
  16. Google Pixel 6 Fingerprint Reader Replacement, Disconnect the fingerprint reader: step 16, image 1 of 2 Google Pixel 6 Fingerprint Reader Replacement, Disconnect the fingerprint reader: step 16, image 2 of 2
    • Use a pair of tweezers to disconnect the fingerprint reader by pulling its cable out of the ZIF connector.
  17. Google Pixel 6 Fingerprint Reader Replacement, Loosen the fingerprint reader adhesive: step 17, image 1 of 1
    • Apply a heated iOpener to the screen where the fingerprint reader is located to loosen the adhesive underneath. Apply the iOpener for at least 3 minutes.
  18. Google Pixel 6 Fingerprint Reader Replacement, Separate the fingerprint reader from the screen: step 18, image 1 of 3 Google Pixel 6 Fingerprint Reader Replacement, Separate the fingerprint reader from the screen: step 18, image 2 of 3 Google Pixel 6 Fingerprint Reader Replacement, Separate the fingerprint reader from the screen: step 18, image 3 of 3
    • Carefully slide an opening pick underneath the fingerprint reader cable to slice its adhesive.
    • Be very gentle during this procedure. Too much force might damage the display. If the adhesive is hard to cut, reapply your iOpener for another minute to loosen it.
    • Be careful not to overheat the screen—the display is susceptible to heat damage.
    • Use your opening pick to separate the fingerprint reader from the screen.
  19. Google Pixel 6 Fingerprint Reader Replacement, Remove the fingerprint reader: step 19, image 1 of 2 Google Pixel 6 Fingerprint Reader Replacement, Remove the fingerprint reader: step 19, image 2 of 2
    • Use a pair of tweezers or your fingers to carefully remove the fingerprint reader.
    • Compare your new replacement part to the original part. You may need to transfer remaining components or remove adhesive backings from the new part before installing.
If possible, turn on your device and test your repair before installing new adhesive and resealing.
To reassemble your device, follow these instructions in reverse order. During reassembly apply new adhesive where necessary after cleaning the relevant areas with isopropyl alcohol (>90%).
To run a diagnostics test with the built-in Pixel Diagnostic tool, click here.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers community for help.
10 other people completed this guide.
Dominik Schnabelrauch
206,475 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,525 Guides authored
3 Comments
Will you ever sell a fingerprint replacement part?
bara soleiman - Reply
Great guide! Using very little alcohol after heating the display can help loosen up the adhesive holding the fingerprint scanner.
Aashish Shrestha - Reply
I am looking at this gide right now because I would like to know how to calibrate my fingerprint after I swap one of your screen on my phone
DWIGHT PR - Reply
Past 24 Hours: 11
Past 7 Days: 81
Past 30 Days: 321
All Time: 8,891
