HP 15-da0012dx RAM Replacement
  1. HP 15-da0012dx RAM Replacement, Battery: step 1, image 1 of 2 HP 15-da0012dx RAM Replacement, Battery: step 1, image 2 of 2
    • Power down your laptop before proceeding.
    • Turn your laptop over so that the Laptop Identification Tag on the underside of the laptop faces the ceiling.
  2. HP 15-da0012dx RAM Replacement: step 2, image 1 of 3 HP 15-da0012dx RAM Replacement: step 2, image 2 of 3 HP 15-da0012dx RAM Replacement: step 2, image 3 of 3
    • Using the plastic opening tools, peel back the plastic feet from the underside of the laptop.
  3. HP 15-da0012dx RAM Replacement: step 3, image 1 of 2 HP 15-da0012dx RAM Replacement: step 3, image 2 of 2
    • Using a Phillips #1 screwdriver, remove the eleven 9.0 mm screws holding the back cover in place.
  4. HP 15-da0012dx RAM Replacement: step 4, image 1 of 2 HP 15-da0012dx RAM Replacement: step 4, image 2 of 2
    • Slide the optical drive out of the computer.
  5. HP 15-da0012dx RAM Replacement: step 5, image 1 of 3 HP 15-da0012dx RAM Replacement: step 5, image 2 of 3 HP 15-da0012dx RAM Replacement: step 5, image 3 of 3
    • Flip the computer over and open the screen.
    • Start from a corner and run the plastic opening tools along the edge of the back cover.
    • After the cover has been completely loosened around the entire perimeter, close the screen and flip the computer over.
    • Gently pry back the cover starting from the middle, bottom edge.
    • Make sure not to bend or crack the plastic cover.
  6. HP 15-da0012dx RAM Replacement: step 6, image 1 of 2 HP 15-da0012dx RAM Replacement: step 6, image 2 of 2
    • Using the Phillips #1 screwdriver, remove the three 8.0 mm screws holding the battery in place.
  7. HP 15-da0012dx RAM Replacement: step 7, image 1 of 2 HP 15-da0012dx RAM Replacement: step 7, image 2 of 2
    • Remove the battery by tilting the top of the battery towards you and pulling the battery away from the mounting tabs.
  8. HP 15-da0012dx RAM Replacement, RAM: step 8, image 1 of 2 HP 15-da0012dx RAM Replacement, RAM: step 8, image 2 of 2
    • Spread the retention clips on either side of the RAM module outward until you hear a click sound.
    • The RAM module should tilt up at a 45 degree angle.
  9. HP 15-da0012dx RAM Replacement: step 9, image 1 of 2 HP 15-da0012dx RAM Replacement: step 9, image 2 of 2
    • Grasp the edge of the RAM module and pull it away from the slot.
    • Follow Steps 8 and 9 to remove both RAM modules.
4 other people completed this guide.
Xavier Hung
914 Reputation
4 Guides authored
UC Davis, Team S20-G4, Lore Winter 2019 Member of UC Davis, Team S20-G4, Lore Winter 2019
UCD-LORE-W19S20G4
3 Members
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 29
All Time: 2,249
