HP 15-dw0xxx Battery Replacement
  1. HP 15-dw0xxx Battery Replacement, Battery: step 1, image 1 of 2 HP 15-dw0xxx Battery Replacement, Battery: step 1, image 2 of 2
    • Remove the seven screws from the rear panel using a Phillips #00 screwdriver.
  2. HP 15-dw0xxx Battery Replacement: step 2, image 1 of 2 HP 15-dw0xxx Battery Replacement: step 2, image 2 of 2
    • Insert the tip of a spudger between the rear panel and the top case to separate the top case from bottom case.
    • Slowly slide the spudger around the device to loosen the bottom part.
    • Pull the bottom case out gently.
  3. HP 15-dw0xxx Battery Replacement: step 3, image 1 of 2 HP 15-dw0xxx Battery Replacement: step 3, image 2 of 2
    • Remove the three screws around the battery using a Phillips #00 screwdriver.
  4. HP 15-dw0xxx Battery Replacement: step 4, image 1 of 1
    • Slowly use your two hands to take the current battery out.
Dalha Mohammed
109 Reputation
1 Guide authored
One Comment
Where can I get a new battery?
Aviv Tenenbaum Haddar - Reply
Past 24 Hours: 7
Past 7 Days: 59
Past 30 Days: 238
All Time: 3,126
