HP 15-dy Battery Replacement
  1. HP 15-dy Battery Replacement, Prepare your laptop for disassembly: step 1, image 1 of 1
    • Fully shut down your laptop and unplug all cables.
  2. HP 15-dy Battery Replacement, Flip your laptop over: step 2, image 1 of 1
    • Flip your laptop over so the rubber feet are facing up.
  3. HP 15-dy Battery Replacement, Peel up an end of the front foot: step 3, image 1 of 3 HP 15-dy Battery Replacement, Peel up an end of the front foot: step 3, image 2 of 3 HP 15-dy Battery Replacement, Peel up an end of the front foot: step 3, image 3 of 3
    • The rubber feet cover a total of six back cover screws.
    • Use an opening pick to peel up an end of the front rubber foot until you can grip it with your fingers.
    • Make sure both the foot and its adhesive peel up together, as they need to be removed as one piece.
  4. HP 15-dy Battery Replacement, Remove the front foot: step 4, image 1 of 3 HP 15-dy Battery Replacement, Remove the front foot: step 4, image 2 of 3 HP 15-dy Battery Replacement, Remove the front foot: step 4, image 3 of 3
    • Peel the front foot away from the back cover and remove it.
  5. HP 15-dy Battery Replacement, Remove the rear foot: step 5, image 1 of 3 HP 15-dy Battery Replacement, Remove the rear foot: step 5, image 2 of 3 HP 15-dy Battery Replacement, Remove the rear foot: step 5, image 3 of 3
    • Use an opening pick to peel up an end of the rear rubber foot until you can grip it with your fingers.
    • Peel the rear foot away from the back cover and remove it.
  6. HP 15-dy Battery Replacement, Reassembly information: step 6, image 1 of 3 HP 15-dy Battery Replacement, Reassembly information: step 6, image 2 of 3 HP 15-dy Battery Replacement, Reassembly information: step 6, image 3 of 3
    Tool used on this step:
    Tesa 61395 Tape
    $5.99
    Buy
    • Note that the rubber feet are different:
    • The rear foot is thicker, with a deeper recess.
    • The front foot is thinner, with a shallower recess.
    • During reassembly:
    • If you're reusing the rubber feet, the leftover adhesive should be tacky enough to reuse.
    • If the leftover adhesive isn't sticky enough or your replacement feet didn't come with adhesive, you can use double-sided tape such as Tesa Tape to secure the feet.
    • Make sure the strips of tape aren't wider than 6 mm, otherwise they may not fit.
    • To install a foot, remove its adhesive liner, lay the foot into its matching recess, and press down firmly along the entire length of the foot to secure it.
  7. HP 15-dy Battery Replacement, Unfasten the back cover: step 7, image 1 of 2 HP 15-dy Battery Replacement, Unfasten the back cover: step 7, image 2 of 2
    • Use a Phillips screwdriver to remove the eight screws securing the back cover:
    • Six 6.5 mm-long silver screws
    • Two 6.7 mm-long black screws
    • Despite the standards, Phillips screwdrivers can vary in size and shape—two drivers labeled as the same size may fit differently in the same screw. Use the size that fits the most snug into the screw head to avoid stripping it.
  8. HP 15-dy Battery Replacement, Open your laptop: step 8, image 1 of 3 HP 15-dy Battery Replacement, Open your laptop: step 8, image 2 of 3 HP 15-dy Battery Replacement, Open your laptop: step 8, image 3 of 3
    • Flip your laptop over and open the screen.
  9. HP 15-dy Battery Replacement, Release the clips: step 9, image 1 of 2 HP 15-dy Battery Replacement, Release the clips: step 9, image 2 of 2
    • Plastic clips secure the back cover to the frame. You'll hear and feel the clips release as you work.
    • Insert the flat side of an opening pick into the seam between the top left edge of the back cover and the frame.
    • Slide the opening pick down to the bottom left corner to release the clips on the left edge.
  10. HP 15-dy Battery Replacement: step 10, image 1 of 2 HP 15-dy Battery Replacement: step 10, image 2 of 2
    • Insert the flat side of an opening pick into the seam between the top right edge of the back cover and the frame.
    • Slide the opening pick down to the bottom right corner to release the clips on the right edge.
  11. HP 15-dy Battery Replacement: step 11, image 1 of 3 HP 15-dy Battery Replacement: step 11, image 2 of 3 HP 15-dy Battery Replacement: step 11, image 3 of 3
    • Insert the flat side of an opening pick between the bottom right corner of the back cover and frame.
    • Slide the opening pick to the bottom left corner to release the remaining clips.
  12. HP 15-dy Battery Replacement, Flip your laptop over: step 12, image 1 of 3 HP 15-dy Battery Replacement, Flip your laptop over: step 12, image 2 of 3 HP 15-dy Battery Replacement, Flip your laptop over: step 12, image 3 of 3
    • Close the screen and flip your laptop back over again.
  13. HP 15-dy Battery Replacement, Remove the back cover: step 13, image 1 of 3 HP 15-dy Battery Replacement, Remove the back cover: step 13, image 2 of 3 HP 15-dy Battery Replacement, Remove the back cover: step 13, image 3 of 3
    • Remove the back cover.
    • To reinstall the back cover, lay it on the frame and firmly press down around the perimeter to engage all of the clips.
  14. HP 15-dy Battery Replacement, Unfasten the battery: step 14, image 1 of 2 HP 15-dy Battery Replacement, Unfasten the battery: step 14, image 2 of 2
    • Given the design of the battery connector, the only way to disconnect the battery is to physically remove it.
    • Try not to bend, crease, deform, poke, or puncture the battery with your tool—a damaged battery is a potential fire hazard.
    • Use a Phillips screwdriver to remove the five 3.7 mm-long screws securing the battery.
  15. HP 15-dy Battery Replacement, Remove the battery: step 15, image 1 of 3 HP 15-dy Battery Replacement, Remove the battery: step 15, image 2 of 3 HP 15-dy Battery Replacement, Remove the battery: step 15, image 3 of 3
    • Gently lift the upper edge of the battery to disconnect its socket from the motherboard.
    • Remove the battery.
    • During reassembly, use the alignment posts to position the battery and press down on the socket to secure it.
    • Never reuse a deformed or damaged battery—it's a fire hazard. Replace it with a new battery.
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
For optimal performance, calibrate your newly installed battery after completing this guide.
Take your e-waste to an R2 or e-Stewards certified recycler. Depending on your region, used HP devices and parts can be returned for reuse or recycling through the HP Planet Partners program.
3 other people completed this guide.
Spencer Day
55,203 Reputation
408 Guides authored
iFixit Member of iFixit
Staff
136 Members
17,430 Guides authored
3 Comments
The guide is fine, with one exception. It appears that the instructions for the rubber strips on the bottom are backwards. The deeper groove for the rubber strip is, in fact, in the back, not the front as stated. The shallower groove is in the front of the computer, not the back.
Kevin “Caoimhín” Cotham - Reply
Thank you for the comment, the guide has been updated!
Spencer Day -
Thank you for the well written guide on replacing the battery on my almost 4 year old HP 15-EF laptop. The steps along with the pics. made it fairly simple and quick.
Cheers!
Ray L.
Horace the Horror - Reply
Past 24 Hours: 3
Past 7 Days: 59
Past 30 Days: 303
All Time: 3,114
