HP 15-dy2046nr Battery Replacement
  1. HP 15-dy2046nr Battery Replacement, Battery: step 1, image 1 of 3 HP 15-dy2046nr Battery Replacement, Battery: step 1, image 2 of 3 HP 15-dy2046nr Battery Replacement, Battery: step 1, image 3 of 3
    • Remove the charging cord from the laptop.
  2. HP 15-dy2046nr Battery Replacement: step 2, image 1 of 2 HP 15-dy2046nr Battery Replacement: step 2, image 2 of 2
    • Remove the 8 total Phillips head screws securing the lower case.
    • Pry the lower case off with as pry tool.
  3. HP 15-dy2046nr Battery Replacement: step 3, image 1 of 3 HP 15-dy2046nr Battery Replacement: step 3, image 2 of 3 HP 15-dy2046nr Battery Replacement: step 3, image 3 of 3
    • Unscrew the 6 Phillips head screws securing the battery.
    • Slide the battery toward you to disconnect it.
    • Remove the battery.
Jessie Weddle
97 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 24
All Time: 105
