HP Chromebook 11 G3 Keyboard Replacement
  1. HP Chromebook 11 G3 Keyboard Replacement, Keyboard Mount: step 1, image 1 of 2 HP Chromebook 11 G3 Keyboard Replacement, Keyboard Mount: step 1, image 2 of 2
    • Flip the laptop upside down so that the lid lies flat on the table.
    • Remove the nine 6mm Phillips #00 screws that line the border.
  2. HP Chromebook 11 G3 Keyboard Replacement: step 2, image 1 of 2 HP Chromebook 11 G3 Keyboard Replacement: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the two rubber feet closest to the hinge using tweezers.
    • Remove the two 6mm Phillips #00 screws revealed under these rubber feet.
    • The rubber feet may tear while removal; preventing this can be difficult, but it won’t harm the laptop. If desired, replace these rubber feet during reassembly.
  3. HP Chromebook 11 G3 Keyboard Replacement: step 3, image 1 of 1
    • Flip the laptop so it is in the upright position.
    • Open the lid.
    • Unsnap the keyboard mount along the border of the laptop using a plastic opening tool.
    • This may require more force than expected. Hearing loud clicks as the plastic opening tool slides along the seam is normal.
  4. HP Chromebook 11 G3 Keyboard Replacement: step 4, image 1 of 3 HP Chromebook 11 G3 Keyboard Replacement: step 4, image 2 of 3 HP Chromebook 11 G3 Keyboard Replacement: step 4, image 3 of 3
    • Tilt the keyboard mount up.
    • Use a spudger to flip up the two ZIF connector retaining flaps for the ribbon cables that connect the keyboard mount to the motherboard.
    • Gently remove both ribbon cables.
  5. HP Chromebook 11 G3 Keyboard Replacement: step 5, image 1 of 1
    • Lift the keyboard mount out of the laptop.
  6. HP Chromebook 11 G3 Keyboard Replacement, Keyboard: step 6, image 1 of 2 HP Chromebook 11 G3 Keyboard Replacement, Keyboard: step 6, image 2 of 2
    Buy
    • Flip the keyboard mount upside-down.
    • Using tweezers, peel off the two pieces of copper tape that keep the keyboard’s metal cover attached to the keyboard mount.
  7. HP Chromebook 11 G3 Keyboard Replacement: step 7, image 1 of 1
    • Using tweezers, pull back the three metallic-colored pieces of tape near the top left corner of the keyboard mount.
  8. HP Chromebook 11 G3 Keyboard Replacement: step 8, image 1 of 2 HP Chromebook 11 G3 Keyboard Replacement: step 8, image 2 of 2
    • Remove the two 4 mm Phillips #00 screws located on either side of the horizontal black fastener located directly above the touchpad.
    • Lift the horizontal black fastener.
  9. HP Chromebook 11 G3 Keyboard Replacement: step 9, image 1 of 3 HP Chromebook 11 G3 Keyboard Replacement: step 9, image 2 of 3 HP Chromebook 11 G3 Keyboard Replacement: step 9, image 3 of 3
    • Use a plastic opening tool to pry the edges of the metal cover.
    • Loosen the adhesive around the perimeter of the metal cover.
    • The adhesive can be difficult to remove. Use tweezers on any troubling sections. After removing the adhesive, take off the keyboard’s metal cover.
    • If the cover doesn’t come off, repeat prying around the edges with a plastic opening tool.
    • Lift the metal cover.
    • Apply adhesive during reassembly to fasten the metal cover onto the keyboard mount.
    • If only certain keys need replacement, stop here. Instead, use tweezers to remove individual keys by loosening their four snap-on clips from the metal backing.
  10. HP Chromebook 11 G3 Keyboard Replacement: step 10, image 1 of 2 HP Chromebook 11 G3 Keyboard Replacement: step 10, image 2 of 2
    • Use a plastic opening tool to disconnect the keyboard from the keyboard mount by prying along the keyboard’s perimeter.
    • Lots of adhesive attaches the keyboard to the keyboard mount. Loud snapping noises and gray, circular plastic debris are common during adhesive removal.
    • After removing enough adhesive, remove the keyboard’s backing.
    • Apply adhesive during reassembly to fasten the keyboard and its metal backing onto the keyboard mount.
2 other people completed this guide.
Rahul Goyal
1,369 Reputation
10 Guides authored
Cal Poly, Team S23-G3, Livingston Spring 2017 Member of Cal Poly, Team S23-G3, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G3
4 Members
12 Guides authored
One Comment
Is it possible to get a keyboard that lights up for the HP Chromebook 11 G3? If so then how?
Vanessa Nations - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 40
All Time: 2,131
