HP Chromebook 14 G5 Battery Replacement
  1. HP Chromebook 14 G5 Battery Replacement, Battery: step 1, image 1 of 2 HP Chromebook 14 G5 Battery Replacement, Battery: step 1, image 2 of 2
    • Remove nine 2.5mm screws embedded in the back cover using the Phillips #0 screwdriver.
    • Remove the back cover using a spudger.
  2. HP Chromebook 14 G5 Battery Replacement: step 2, image 1 of 1
    • Remove the 4.1mm screws using the Phillips #00 screwdriver.
  3. HP Chromebook 14 G5 Battery Replacement: step 3, image 1 of 3 HP Chromebook 14 G5 Battery Replacement: step 3, image 2 of 3 HP Chromebook 14 G5 Battery Replacement: step 3, image 3 of 3
    • Disconnect the FFC.
    • Remove the battery from the device.
0 Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 41
All Time: 1,649
