HP Chromebook 14-Q010DX USB/SD card Replacement
  1. HP Chromebook 14-Q010DX USB/SD card Replacement, Keyboard and Touchpad: step 1, image 1 of 2 HP Chromebook 14-Q010DX USB/SD card Replacement, Keyboard and Touchpad: step 1, image 2 of 2
    • Flip the laptop with the base of the laptop is facing you.
    • Using the #00 screwdriver, unscrew these screws.
  2. HP Chromebook 14-Q010DX USB/SD card Replacement: step 2, image 1 of 3 HP Chromebook 14-Q010DX USB/SD card Replacement: step 2, image 2 of 3 HP Chromebook 14-Q010DX USB/SD card Replacement: step 2, image 3 of 3
    • Warning! When prying open a laptop it could require some force, but it also has fragile connectors underneath. Use caution so as to avoid breaking these connectors.
    • Start from the top right corner of the laptop and work clockwise with an iFixit opening tool or spudger to pry the keyboard from the frame of the laptop.
  3. HP Chromebook 14-Q010DX USB/SD card Replacement: step 3, image 1 of 3 HP Chromebook 14-Q010DX USB/SD card Replacement: step 3, image 2 of 3 HP Chromebook 14-Q010DX USB/SD card Replacement: step 3, image 3 of 3
    • Warning! Handle the flaps and ribbon cables with care to prevent damage.
    • Gently pull the keyboard in the opposite direction of the screen, so the wires beneath are exposed.
    • Lift the black flap and pull the blue ribbon gently towards you until it is disconnected.
    • Lift the white flap and pull the blue ribbon towards you until it is disconnected.
  4. HP Chromebook 14-Q010DX USB/SD card Replacement: step 4, image 1 of 1
    • Lift keyboard slightly and remove the strip gently to prevent damaging any parts.
    • The tape has no function other than to keep the wire tucked away.
  5. HP Chromebook 14-Q010DX USB/SD card Replacement: step 5, image 1 of 1
    • Set aside the detached keyboard.
  6. HP Chromebook 14-Q010DX USB/SD card Replacement, Speaker: step 6, image 1 of 3 HP Chromebook 14-Q010DX USB/SD card Replacement, Speaker: step 6, image 2 of 3 HP Chromebook 14-Q010DX USB/SD card Replacement, Speaker: step 6, image 3 of 3
    • Undo the black tape located on the bottom from the frame of the laptop.
    • Using fingers or the spudger, slide out the black connector indicated on the left.
    • Use a #00 screwdriver to remove the two screws.
  7. HP Chromebook 14-Q010DX USB/SD card Replacement: step 7, image 1 of 2 HP Chromebook 14-Q010DX USB/SD card Replacement: step 7, image 2 of 2
    • Gently remove the speakers.
  8. HP Chromebook 14-Q010DX USB/SD card Replacement, Battery: step 8, image 1 of 2 HP Chromebook 14-Q010DX USB/SD card Replacement, Battery: step 8, image 2 of 2
    • Note the shape that this wire strip is resting at and that the blue tip of the strip goes into the right connector for reassembly.
    • Lift the black flaps and gently pull the strip out.
    • Set the strip aside.
  9. HP Chromebook 14-Q010DX USB/SD card Replacement: step 9, image 1 of 3 HP Chromebook 14-Q010DX USB/SD card Replacement: step 9, image 2 of 3 HP Chromebook 14-Q010DX USB/SD card Replacement: step 9, image 3 of 3
    • Remove the screw.
    • Use your fingers to pull the white tab out of the black slot above the battery.
  10. HP Chromebook 14-Q010DX USB/SD card Replacement: step 10, image 1 of 1
    • Gently remove battery.
  11. HP Chromebook 14-Q010DX USB/SD card Replacement, USB/SD card: step 11, image 1 of 2 HP Chromebook 14-Q010DX USB/SD card Replacement, USB/SD card: step 11, image 2 of 2
    • Remove screw indicated by the red circle at the top of the card port.
  12. HP Chromebook 14-Q010DX USB/SD card Replacement: step 12, image 1 of 1
    • Gently remove the USB/SD card port.
Kevin Piper
1,599 Reputation
6 Guides authored
USF Tampa, Team 17-2, Watkins Winter 2015 Member of USF Tampa, Team 17-2, Watkins Winter 2015
USFT-WATKINS-W15S17G2
4 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 12
All Time: 503
