HP Deskjet 1055 Ink Cartridge Replacement
Daniel
Daniel and 5 other contributors
Last updated on April 6, 2023
5 minutes
Easy
Introduction
Go to step 1
Install the ink cartridge(s) when the printer runs out of ink or when the ink warning lights flash to prevent running out.
iFixit earns commission when you buy through these links.
  1. HP Deskjet 1055 Ink Cartridge Replacement, Ink Cartridge: step 1, image 1 of 1
    • Turn on the printer by pressing the power button.
  2. HP Deskjet 1055 Ink Cartridge Replacement: step 2, image 1 of 2 HP Deskjet 1055 Ink Cartridge Replacement: step 2, image 2 of 2
    • Place your index finger in the opening on the front of the printer (right side below scanner/copier) and pull the door down.
    • Pull down on the tab that lies in the middle of the newly-exposed gray cover.
  3. HP Deskjet 1055 Ink Cartridge Replacement: step 3, image 1 of 1
    • The tri-color cartridge sits on the left side; the black cartridge sits on the right.
    • Grab the cartridge from the top and bottom and pull down until it clicks.
    • Pull out the freed cartridge.
  4. HP Deskjet 1055 Ink Cartridge Replacement: step 4, image 1 of 3 HP Deskjet 1055 Ink Cartridge Replacement: step 4, image 2 of 3 HP Deskjet 1055 Ink Cartridge Replacement: step 4, image 3 of 3
    • Take the replacement cartridge out of its packaging and pull off the plastic tab.
    • Do not touch the electrical contacts or ink nozzles. Touching may cause malfunctions.
    • Hold the cartridge on both sides with the title sticker facing upwards.
  5. HP Deskjet 1055 Ink Cartridge Replacement: step 5, image 1 of 2 HP Deskjet 1055 Ink Cartridge Replacement: step 5, image 2 of 2
    • Slide the cartridge directly into open slot (tri-color on the left, black on the right).
    • Push it forward until you hear it snap.
  6. HP Deskjet 1055 Ink Cartridge Replacement: step 6, image 1 of 1
    • Close the gray access door.
  7. HP Deskjet 1055 Ink Cartridge Replacement: step 7, image 1 of 2 HP Deskjet 1055 Ink Cartridge Replacement: step 7, image 2 of 2
    • Wait 30 seconds for the alignment page to print.
    • Open up the scanner lid and place the alignment page face-down in the right-front corner of the glass.
    • Close the lid.
  8. HP Deskjet 1055 Ink Cartridge Replacement: step 8, image 1 of 1
    • Press the color copy button to begin scan.
    • Wait until the power button stops blinking.
When the power button stops blinking, your can now use your printer.
4 other people completed this guide.
Daniel
314 Reputation
2 Guides authored
Cal Poly, Team 9-18, Amido Fall 2012 Member of Cal Poly, Team 9-18, Amido Fall 2012
CPSU-AMIDO-F12S9G18
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 41
All Time: 16,207
