HP EliteBook 820 G3 Battery Replacement
  1. HP EliteBook 820 G3 Battery Replacement, Back Cover: step 1, image 1 of 2 HP EliteBook 820 G3 Battery Replacement, Back Cover: step 1, image 2 of 2
    • Remove the eleven 3 mm screws with a Phillips #00 screwdriver.
    • Keep track of where the screw covers were attached to as there are four different sizes.
  2. HP EliteBook 820 G3 Battery Replacement: step 2, image 1 of 2 HP EliteBook 820 G3 Battery Replacement: step 2, image 2 of 2
    • Remove the SD card blank and the single 3 mm screw beneath it using a Phillips #00 screwdriver.
    • Lift off the back cover with your hands.
  3. HP EliteBook 820 G3 Battery Replacement, Battery: step 3, image 1 of 3 HP EliteBook 820 G3 Battery Replacement, Battery: step 3, image 2 of 3 HP EliteBook 820 G3 Battery Replacement, Battery: step 3, image 3 of 3
    • Loosen the single captive screw holding the battery in place using a Phillips #00 screwdriver.
    • Lift the black tab upwards and lift the battery out of its slot.
2 other people completed this guide.
Sarah Bisimwa
247 Reputation
2 Guides authored
Gateway, Team 1-1, Class Fall 2022 Member of Gateway, Team 1-1, Class Fall 2022
GCC-CLASS-F22S1G1
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 73
All Time: 1,311
