HP Pavilion x360 14-ba253cl Battery Replacement
  1. HP Pavilion x360 14-ba253cl Battery Replacement, Keyboard: step 1, image 1 of 1
    • Use the Jimmy to remove the footpads located at the bottom of the laptop.
  2. HP Pavilion x360 14-ba253cl Battery Replacement: step 2, image 1 of 1
    • Remove three 4.0mm Phillips #0 screws from the top of the cover.
    • Remove two 6.0mm Phillips #0 screws underneath each of the back footpads.
    • Remove one 4.mm Phillips #0 screw beneath the divot.
  3. HP Pavilion x360 14-ba253cl Battery Replacement: step 3, image 1 of 1
    • Turn the computer onto its base, with the computer open and the keys facing upward.
  4. HP Pavilion x360 14-ba253cl Battery Replacement: step 4, image 1 of 1
    • Use an opening pick to separate the keyboard from the base of the laptop.
  5. HP Pavilion x360 14-ba253cl Battery Replacement: step 5, image 1 of 1
    • Raise the keyboard slightly to gain access to the touch pad and keyboard cables.
    • Using a spudger, lift up the plastic locks that connect the ribbon cable to the system board.
    • Use the blue plastic tab on the ribbon cable to pull it out from the system board.
    • Remove the keyboard from the laptop.
  6. HP Pavilion x360 14-ba253cl Battery Replacement, Battery: step 6, image 1 of 1
    • Remove six 3mm Phillips #00 screws around the perimeter of the battery.
  7. HP Pavilion x360 14-ba253cl Battery Replacement: step 7, image 1 of 1
    • Carefully lift the battery starting from the lower right corner and disconnect it from the system board.
5 other people completed this guide.
One Comment
Thanks, it was useful
Oleg - Reply
Past 24 Hours: 8
Past 7 Days: 27
Past 30 Days: 131
All Time: 8,171
