HP ProBook 4740s RAM Replacement
  1. HP ProBook 4740s RAM Replacement, Removing the battery and backplate: step 1, image 1 of 2 HP ProBook 4740s RAM Replacement, Removing the battery and backplate: step 1, image 2 of 2
    • Hold in both "levers" so the battery pops out of place. Do this again to remove the backplate.
  2. HP ProBook 4740s RAM Replacement, Removing the old RAM: step 2, image 1 of 3 HP ProBook 4740s RAM Replacement, Removing the old RAM: step 2, image 2 of 3 HP ProBook 4740s RAM Replacement, Removing the old RAM: step 2, image 3 of 3
    • Press on both clasps outwards so that the stick of RAM lifts up out of place. Then, simply remove it.
  3. HP ProBook 4740s RAM Replacement, Installing the new RAM: step 3, image 1 of 1
    • Take a replacemnt stick of RAM, place it in the slot and push down until it clicks into place.
  4. HP ProBook 4740s RAM Replacement, Installing the Backplate and battery: step 4, image 1 of 2 HP ProBook 4740s RAM Replacement, Installing the Backplate and battery: step 4, image 2 of 2
    • Simply slide the backplate into place, from the bottom end to the top end of the laptop. Then, take the battery and push until it clicks into place.
Easy replacemnt of a faulty RAM stick. Same instructions apply when upgrading.
Mevaa
109 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 50
