HTC Rhyme Volume Button Replacement
  1. HTC Rhyme Volume Button  Replacement, Removing Back Cover: step 1, image 1 of 1
    • Slide the bottom back cover off of the phone.
  2. HTC Rhyme Volume Button  Replacement: step 2, image 1 of 1
    • Locate the four screws on the plastic cover and unscrew them.
  3. HTC Rhyme Volume Button  Replacement: step 3, image 1 of 1
    • Pry the sticker off from the sides.
    • You can use a metal spudger to do this.
    • Peel the sticker off with your hands.
  4. HTC Rhyme Volume Button  Replacement, Remove the plastic cover: step 4, image 1 of 1
    • Remove the plastic cover using your hands.
  5. HTC Rhyme Volume Button  Replacement: step 5, image 1 of 1
    • Remove the yellow ribbon.
  6. HTC Rhyme Volume Button  Replacement: step 6, image 1 of 3 HTC Rhyme Volume Button  Replacement: step 6, image 2 of 3 HTC Rhyme Volume Button  Replacement: step 6, image 3 of 3
    • Lift up the blue flaps underneath the battery.
    • Lift up the black flap at the top of the phone.
    • Lift up the black flap at the bottom of the phone.
  7. HTC Rhyme Volume Button  Replacement, Remove the Motherboard: step 7, image 1 of 2 HTC Rhyme Volume Button  Replacement, Remove the Motherboard: step 7, image 2 of 2
    • Remove all 4 screws.
    • Carefully remove the motherboard with your hands.
  8. HTC Rhyme Volume Button  Replacement, Removing the back plastic casing: step 8, image 1 of 3 HTC Rhyme Volume Button  Replacement, Removing the back plastic casing: step 8, image 2 of 3 HTC Rhyme Volume Button  Replacement, Removing the back plastic casing: step 8, image 3 of 3
    • Pry the back plastic casing off with your hands.
  9. HTC Rhyme Volume Button  Replacement: step 9, image 1 of 2 HTC Rhyme Volume Button  Replacement: step 9, image 2 of 2
    • Use the tip of a screwdriver to push the button out of the panel.
Frederick
119 Reputation
1 Guide authored
USF Tampa, Team 9-6, Leahy Fall 2014 Member of USF Tampa, Team 9-6, Leahy Fall 2014
USFT-LEAHY-F14S9G6
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 13
All Time: 282
