Hello Zee Smart Core Front Case Replacement
  1. Hello Zee Smart Core Front Case Replacement, Front Case: step 1, image 1 of 2 Hello Zee Smart Core Front Case Replacement, Front Case: step 1, image 2 of 2
    • This model is 64GB
  2. Hello Zee Smart Core Front Case Replacement, Opening: step 2, image 1 of 3 Hello Zee Smart Core Front Case Replacement, Opening: step 2, image 2 of 3 Hello Zee Smart Core Front Case Replacement, Opening: step 2, image 3 of 3
    • Insert the spudger into a corner and separate the halves
    • Do not puncture the battery
  3. Hello Zee Smart Core Front Case Replacement, Main board unmounting: step 3, image 1 of 2 Hello Zee Smart Core Front Case Replacement, Main board unmounting: step 3, image 2 of 2
    • Use your spudger’s pointed tip to unscrew the screws
  4. Hello Zee Smart Core Front Case Replacement, Board removal: step 4, image 1 of 2 Hello Zee Smart Core Front Case Replacement, Board removal: step 4, image 2 of 2
    • Use your spudger to pry up the board from the sides
    • Do not break it
    • Do not pry from the battery side
  5. Hello Zee Smart Core Front Case Replacement, Electronics removal: step 5, image 1 of 3 Hello Zee Smart Core Front Case Replacement, Electronics removal: step 5, image 2 of 3 Hello Zee Smart Core Front Case Replacement, Electronics removal: step 5, image 3 of 3
    • CAREFULLY pry under the battery to remove it
    • there are no permanent adhesives, though there may be sticky tape
    • Spectate everything from the case
To reassemble your device, follow these instructions in reverse order, using your replacement case instead of the one described.
9021007
4,599 Reputation
25 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 583
