Home construction tool fixing screws toaster repair (Model #1)
  1. Home construction tool fixing screws toaster repair (Model #1), Home construction tool fixing screws toaster repair (Model #1): step 1, image 1 of 3 Home construction tool fixing screws toaster repair (Model #1), Home construction tool fixing screws toaster repair (Model #1): step 1, image 2 of 3 Home construction tool fixing screws toaster repair (Model #1), Home construction tool fixing screws toaster repair (Model #1): step 1, image 3 of 3
    • Homemade construction tool, for holding screws using 3 options, Neodymium Magnet, left side slot for 6 mm head screw and right side slot for 5 mm head screw.
    • Photo of materials to be used, there are more materials than those used in this design, since I have made 2 variants of the homemade screw-holding tool at the same time, in another document I show the 2nd tool. A 1x1x20 Cm wooden strip has been used, any other similar will work, Neodymium Magnet, and heat shrink tubing.
    • Neodymium magnet.
  2. Home construction tool fixing screws toaster repair (Model #1): step 2, image 1 of 3 Home construction tool fixing screws toaster repair (Model #1): step 2, image 2 of 3 Home construction tool fixing screws toaster repair (Model #1): step 2, image 3 of 3
    • Wooden strip of 1x1x20 cm, the measure of 20 cm depends on the needs of each one, other measures can be used. I used the 1x1 batten that I had that was quite adapted to the idea of ​​having 3 screw fixing points.
    • Cut the ribbon at 20 cm, the tip is cut at 45º to prevent it from hindering the insertion into the toaster.
  3. Home construction tool fixing screws toaster repair (Model #1): step 3, image 1 of 3 Home construction tool fixing screws toaster repair (Model #1): step 3, image 2 of 3 Home construction tool fixing screws toaster repair (Model #1): step 3, image 3 of 3
    • To fix the Neodymium magnet to the wooden strip, just 1 drop of instant-drying glue, cyanoacrylate type.
    • If we put a screw in the magnet, it can be handled and positioned in the wooden strip more easily.
  4. Home construction tool fixing screws toaster repair (Model #1): step 4, image 1 of 3 Home construction tool fixing screws toaster repair (Model #1): step 4, image 2 of 3 Home construction tool fixing screws toaster repair (Model #1): step 4, image 3 of 3
    • Views of the Neodymium magnet fixed to the wooden strip.
  5. Home construction tool fixing screws toaster repair (Model #1): step 5, image 1 of 3 Home construction tool fixing screws toaster repair (Model #1): step 5, image 2 of 3 Home construction tool fixing screws toaster repair (Model #1): step 5, image 3 of 3
    • On the 2 sides of the wooden strip, next to the magnet, I have made 2 small holes, (Depth 3 to 4 mm) of 5 mm and 6 mm on the other side, to be able to insert "fixing" two separate 5 mm head screws and 6mm.
  6. Home construction tool fixing screws toaster repair (Model #1): step 6, image 1 of 3 Home construction tool fixing screws toaster repair (Model #1): step 6, image 2 of 3 Home construction tool fixing screws toaster repair (Model #1): step 6, image 3 of 3
    • View of the 6 mm and 5 mm screws in the test positioning in the batten.
  7. Home construction tool fixing screws toaster repair (Model #1): step 7, image 1 of 2 Home construction tool fixing screws toaster repair (Model #1): step 7, image 2 of 2
    • Views of one of the 4mm deep holes
  8. Home construction tool fixing screws toaster repair (Model #1): step 8, image 1 of 3 Home construction tool fixing screws toaster repair (Model #1): step 8, image 2 of 3 Home construction tool fixing screws toaster repair (Model #1): step 8, image 3 of 3
    • This step is merely decorative, it is made with a red shrink tube to give it a decorative end and to make it easier to see when it is inserted into the toaster.
    • The heat shrink tubing shrinks and adapts to the surface where it is placed by applying hot air.
  9. Home construction tool fixing screws toaster repair (Model #1): step 9, image 1 of 1
    • Heat shrink tubing and as it is called in some countries.
  10. Home construction tool fixing screws toaster repair (Model #1): step 10, image 1 of 3 Home construction tool fixing screws toaster repair (Model #1): step 10, image 2 of 3 Home construction tool fixing screws toaster repair (Model #1): step 10, image 3 of 3
    • Views of the finished homemade tool, this is a new design of the original tool that I used, this new design is specially dedicated to the friends of IFIXIT, in another I will document the 2nd Tool that I have made, more elaborate. And I will show the 3 options.
  11. Home construction tool fixing screws toaster repair (Model #1): step 11, image 1 of 3 Home construction tool fixing screws toaster repair (Model #1): step 11, image 2 of 3 Home construction tool fixing screws toaster repair (Model #1): step 11, image 3 of 3
    • Views of the finished tool, in detail.
  12. Home construction tool fixing screws toaster repair (Model #1): step 12, image 1 of 1
    • Example of use inside a toaster.
    • In another document I will detail the construction of the 2nd homemade Tool to hold screws and facilitate the task of repairing a toaster with the broken Nicrom thread.
Finish Line
Special thanks to these translators:
es en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Carlos López (España - Spain)
55,428 Reputation
168 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,503 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 21
All Time: 123
