How to Add a Hole to a Belt
  1. How to Add a Hole to a Belt, How to Add a Hole to a Belt: step 1, image 1 of 1
    • Wrap the belt around yourself.
    • Mark with a pen, pencil, or marker where the hole should be placed.
  2. How to Add a Hole to a Belt: step 2, image 1 of 2 How to Add a Hole to a Belt: step 2, image 2 of 2
    • Use a tape measure to center the hole in the middle of the belt.
    • Make sure the hole is in line with the previous hole as well.
  3. How to Add a Hole to a Belt: step 3, image 1 of 1
    • Grab a hand drill with a circular bit similar to the size of the current belt holes.
    • For reference, a 5/32 bit was used here.
  4. How to Add a Hole to a Belt: step 4, image 1 of 2 How to Add a Hole to a Belt: step 4, image 2 of 2
    • Place the belt over a scrap piece of wood or on a material that can be drilled on.
  5. How to Add a Hole to a Belt: step 5, image 1 of 2 How to Add a Hole to a Belt: step 5, image 2 of 2
    • Drill all the way through the belt where it has been marked.
  6. How to Add a Hole to a Belt: step 6, image 1 of 2 How to Add a Hole to a Belt: step 6, image 2 of 2
    • Move the drill up and down a few times in place to ensure the hole is smooth around the edges.
    • Be sure the belt buckle fits in the new hole.
After you complete the final step to your liking the fix is done.
Alexa Velazquez
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 10
Past 30 Days: 36
All Time: 1,322
