How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller
  1. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller, How to Clean the L2 and R2 Buttons: step 1, image 1 of 2 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller, How to Clean the L2 and R2 Buttons: step 1, image 2 of 2
    • Use a Phillips #00 screwdriver to remove the four 6.0 mm screws located on the back of the controller.
  2. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: step 2, image 1 of 3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: step 2, image 2 of 3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: step 2, image 3 of 3
    • Separate the front and the back of the controller by pulling both pieces apart at the same time.
    • Be very careful and gentle when pulling the shells apart because the blue ribbon can become detached and damaged.
  3. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: step 3, image 1 of 2 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: step 3, image 2 of 2
    • Carefully unplug the blue ribbon from the body of the controller shell.
  4. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: step 4, image 1 of 3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: step 4, image 2 of 3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: step 4, image 3 of 3
    • Remove the left and right triggers by wiggling the buttons sideways until they are completely off.
  5. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: step 5, image 1 of 2 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: step 5, image 2 of 2
    • Take the Q-tip and soak it into the isopropyl alcohol.
    • Clean around the trigger button area as well as under and above the rubber padding.
  6. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: step 6, image 1 of 3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: step 6, image 2 of 3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: step 6, image 3 of 3
    • Put the L2 and R2 buttons back into place by simply forcing them into position until properly locked.
  7. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: step 7, image 1 of 2 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: step 7, image 2 of 2
    • Attach the blue ribbon back into its original location so that the two shells of the controller are connected.
  8. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: step 8, image 1 of 2 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: step 8, image 2 of 2
    • Put the two shells of the controller together by pushing them together at the same time.
  9. How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: step 9, image 1 of 3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: step 9, image 2 of 3 How to Clean The R2 and L2 Buttons on a Dualshock 4 CUH-ZCT2 Controller: step 9, image 3 of 3
    • Screw the four 6.0mm screws on the back of the controller using the Phillips #00 screwdriver.
Finish Line
Joseph Cao
169 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 21
Past 7 Days: 147
Past 30 Days: 399
All Time: 1,624
