How to Disable Auto Boot
  1. How to Disable Auto Boot, How to Disable Auto Boot: step 1, image 1 of 3 How to Disable Auto Boot, How to Disable Auto Boot: step 1, image 2 of 3 How to Disable Auto Boot, How to Disable Auto Boot: step 1, image 3 of 3
    • Power on your Mac and launch Terminal.
    • To launch Terminal, you can either use Spotlight Search or navigate to Applications / Utilities in Finder and double click the Terminal icon.
  2. How to Disable Auto Boot: step 2, image 1 of 2 How to Disable Auto Boot: step 2, image 2 of 2
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return].
    • Your [return] key may also be labeled ⏎ or [enter].
    • If you are prompted for an administrative password, type the password and press [return].
    • Your password will not be displayed in Terminal.
  3. How to Disable Auto Boot: step 3, image 1 of 1
    • You can now safely power down your Mac and remove the bottom case, without it accidentally powering on.
    • Remember, you must still disconnect the battery before servicing internal components.
  4. How to Disable Auto Boot: step 4, image 1 of 3 How to Disable Auto Boot: step 4, image 2 of 3 How to Disable Auto Boot: step 4, image 3 of 3
    • When your repair is complete and your Mac is successfully reassembled, you can re-enable the Auto Boot feature.
    • sudo nvram AutoBoot=%03
    • Press [return].
    • Alternatively, you may reset your Mac's NVRAM to re-enable Auto Boot.
Congrats! You're done.
55 other people completed this guide.
Jeff Suovanen
429,544 Reputation
259 Guides authored
iFixit Member of iFixit
Staff
137 Members
17,523 Guides authored
17 Comments
hello may i ask, how do u make it Jeff$? mine’s scarlet$ and i want to change it but idk how
srhshahdzan - Reply
I can’t type anything into the terminal…what am I doing wrong?
Linda Sussman - Reply
HELP
it doesn’t work on MacBook Air><
my sister’s pro did work, thanks!! but mine can’t do so. what should I do???
Ching-Hsien Chou - Reply
This code change DOES NOT work.
MFMauceri - Reply
This was a great help to replace my MacBook Pro battery. Great step by step explanations. I received kit and followed the directions.
Simon Tezzo - Reply
Past 24 Hours: 108
Past 7 Days: 765
Past 30 Days: 3,647
All Time: 140,959
