How to Fix Jammed Nintendo Switch ZR and ZL buttons
  1. How to Fix Jammed Nintendo Switch ZR and ZL buttons, Unscrew the back cover: step 1, image 1 of 1
    • Using the Y00 Tri-Point screwdriver, remove four M1.4 x 5mm screws to loosen the hard plastic back of the Joy-Con.
    • After the screws are removed, lift the cover to reveal the inside of the Joy-Con and locate the ZL button.
    • The button exposed could either be the ZL or the ZR depending on which Joy-Con needs to be fixed.
    • Use tweezers to lift the ZL button a little then pull upwards to get it back into place.
    • Once the button is back in place, place the hard cover back on the Joy-Con and screw it back on.
    • Click the button a couple times to ensure that it's back in place and working.
    • This may either be the ZL or ZR button depending on the Joy-Con being fixed.
  2. How to Fix Jammed Nintendo Switch ZR and ZL buttons: step 5, image 1 of 1
    • Resume gameplay!
After following those 7 steps, your gameplay should return to its original state. If the other Joy-Con also has a jammed ZL or ZR button simply repeat the 7 steps above.
12 other people completed this guide.
0 Comments
Past 24 Hours: 38
Past 7 Days: 296
Past 30 Days: 1,549
All Time: 91,906
