How to Fix Nintendo Switch Joy-Con Stick Drift (Without Disassembling)
  1. How to Fix Nintendo Switch Joy-Con Stick Drift (Without Disassembling), Preparing the Joy-Cons: step 1, image 1 of 2 How to Fix Nintendo Switch Joy-Con Stick Drift (Without Disassembling), Preparing the Joy-Cons: step 1, image 2 of 2
    • Hold the button on the black button on the Joy-Con, and slide the controller off the console.
  2. How to Fix Nintendo Switch Joy-Con Stick Drift (Without Disassembling), Hold the Joystick: step 2, image 1 of 1
    • Push and hold the joystick to the side.
  3. How to Fix Nintendo Switch Joy-Con Stick Drift (Without Disassembling), Hold the Joystick With Tweezers: step 3, image 1 of 1
    Tool used on this step:
    Buy
    • Lift the rubber grip and hold it with tweezers.
  4. How to Fix Nintendo Switch Joy-Con Stick Drift (Without Disassembling), Spray the Contact Cleaner: step 4, image 1 of 2 How to Fix Nintendo Switch Joy-Con Stick Drift (Without Disassembling), Spray the Contact Cleaner: step 4, image 2 of 2
    • Aim the nozzle of the 404B Cleaner into the joystick gap, and spray it up to twice.
  5. How to Fix Nintendo Switch Joy-Con Stick Drift (Without Disassembling), Rotate the Joystick: step 5, image 1 of 2 How to Fix Nintendo Switch Joy-Con Stick Drift (Without Disassembling), Rotate the Joystick: step 5, image 2 of 2
    • Rotate the joystick for 30-60 seconds to allow the cleaner to circulate.
  6. How to Fix Nintendo Switch Joy-Con Stick Drift (Without Disassembling), Drying: step 6, image 1 of 1
    • Let the joystick dry for 5-10 minutes.
  7. How to Fix Nintendo Switch Joy-Con Stick Drift (Without Disassembling), Testing: step 7, image 1 of 1
    • Slide the Joy-Con back on to the console
    • Test the joystick in settings
    • To reach the testing application, Navigate System Settings > Controllers and Sensors > Calibrate Control Sticks.
If the problem is not solved, repeat steps 1-6, and then test the Joy-Con.
Russell Repair Co.
2,135 Reputation
4 Guides authored
One Comment
Eres un genio de la simpleza, barbaro
sary maste - Reply
Past 24 Hours: 9
Past 7 Days: 51
Past 30 Days: 179
All Time: 3,936
