How to Fix a Broken Strap on a Strapback Hat
  1. How to Fix a Broken Strap on a Strapback Hat, How to Fix a Broken Strap on a Strapback Hat: step 1, image 1 of 3 How to Fix a Broken Strap on a Strapback Hat, How to Fix a Broken Strap on a Strapback Hat: step 1, image 2 of 3 How to Fix a Broken Strap on a Strapback Hat, How to Fix a Broken Strap on a Strapback Hat: step 1, image 3 of 3
    • Measure the thread.
    • We recommend an arms-length amount of thread to ensure its enough to complete the fix without needing more thread.
    • Cut the thread at desired length.
  2. How to Fix a Broken Strap on a Strapback Hat: step 2, image 1 of 2 How to Fix a Broken Strap on a Strapback Hat: step 2, image 2 of 2
    • Thread the needle.
  3. How to Fix a Broken Strap on a Strapback Hat: step 3, image 1 of 2 How to Fix a Broken Strap on a Strapback Hat: step 3, image 2 of 2
    • Pull the thread through the needle until both ends of the thread meet.
    • Tie a knot at the end of the thread.
  4. How to Fix a Broken Strap on a Strapback Hat: step 4, image 1 of 2 How to Fix a Broken Strap on a Strapback Hat: step 4, image 2 of 2
    • Position the strap to where it was originally located on the hat.
  5. How to Fix a Broken Strap on a Strapback Hat: step 5, image 1 of 2 How to Fix a Broken Strap on a Strapback Hat: step 5, image 2 of 2
    • Ensure that the strap doesn't move by using a binder clip to hold it in place.
  6. How to Fix a Broken Strap on a Strapback Hat: step 6, image 1 of 3 How to Fix a Broken Strap on a Strapback Hat: step 6, image 2 of 3 How to Fix a Broken Strap on a Strapback Hat: step 6, image 3 of 3
    • Starting on the inside of the hat, poke the needle through the cap and loose strap.
    • Pull the needle through the fabric and out the other end.
  7. How to Fix a Broken Strap on a Strapback Hat: step 7, image 1 of 2 How to Fix a Broken Strap on a Strapback Hat: step 7, image 2 of 2
    • Move the needle a few millimeters to the left and poke the needle through the front of the hat.
    • Pull the needle out on the other end.
  8. How to Fix a Broken Strap on a Strapback Hat: step 8, image 1 of 2 How to Fix a Broken Strap on a Strapback Hat: step 8, image 2 of 2
    • Repeat steps 6 and 7 until the strap is fully sewn onto the hat.
  9. How to Fix a Broken Strap on a Strapback Hat: step 9, image 1 of 3 How to Fix a Broken Strap on a Strapback Hat: step 9, image 2 of 3 How to Fix a Broken Strap on a Strapback Hat: step 9, image 3 of 3
    • Tie a knot as close to the base of the hat as possible and cut the thread.
  10. How to Fix a Broken Strap on a Strapback Hat: step 10, image 1 of 1
    • Your hat is fixed and ready to wear!
Congratulations! With some simple hand sewing, you were able to fix the broken strap on your hat.
Sarah Sy
181 Reputation
1 Guide authored
UC Davis, Team 1-1, Andersen Winter 2023 Member of UC Davis, Team 1-1, Andersen Winter 2023
UCD-ANDERSEN-W23S1G1
3 Members
1 Guide authored
0 Comments
Past 24 Hours: 6
Past 7 Days: 84
Past 30 Days: 371
All Time: 3,326
