How to Fix a Crooked Cabinet
  1. How to Fix a Crooked Cabinet, Examine the Issue: step 1, image 1 of 3 How to Fix a Crooked Cabinet, Examine the Issue: step 1, image 2 of 3 How to Fix a Crooked Cabinet, Examine the Issue: step 1, image 3 of 3
    • Examine which door needs to be adjusted and to what extent.
  2. How to Fix a Crooked Cabinet, Unscrew the Bottom Screws: step 2, image 1 of 3 How to Fix a Crooked Cabinet, Unscrew the Bottom Screws: step 2, image 2 of 3 How to Fix a Crooked Cabinet, Unscrew the Bottom Screws: step 2, image 3 of 3
    • Hold onto the cabinet as you unscrew the two bottom screws to reposition it.
    • Tighten the screws to adjust accordingly.
  3. How to Fix a Crooked Cabinet, Repeat with the Top Screws: step 3, image 1 of 3 How to Fix a Crooked Cabinet, Repeat with the Top Screws: step 3, image 2 of 3 How to Fix a Crooked Cabinet, Repeat with the Top Screws: step 3, image 3 of 3
    • Repeat Step 2 with the screws at the top.
  4. How to Fix a Crooked Cabinet, Adjust to Gap: step 4, image 1 of 1
    • The gap should be even from top to bottom, ensure that it is and hold the cabinet in place to adjust if it is not.
  5. How to Fix a Crooked Cabinet, Feel Accomplished: step 5, image 1 of 2 How to Fix a Crooked Cabinet, Feel Accomplished: step 5, image 2 of 2
    • You've done it! As long as the gap is even, your results should be just like this.
    • Great job!
Finish Line
Elmore Smith
148 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 14
Past 30 Days: 85
All Time: 960
