How to Manually Eject a Stuck Disc in a PlayStation 5
  1. How to Manually Eject a Stuck Disc in a PlayStation 5, How to Manually Eject a Stuck Disc in a PlayStation 5: step 1, image 1 of 3 How to Manually Eject a Stuck Disc in a PlayStation 5, How to Manually Eject a Stuck Disc in a PlayStation 5: step 1, image 2 of 3 How to Manually Eject a Stuck Disc in a PlayStation 5, How to Manually Eject a Stuck Disc in a PlayStation 5: step 1, image 3 of 3
    • Unplug all cables going into the console (power, ethernet, hdmi and etc).
    • This should be done for your safety and for the safety of the device.
  2. How to Manually Eject a Stuck Disc in a PlayStation 5: step 2, image 1 of 3 How to Manually Eject a Stuck Disc in a PlayStation 5: step 2, image 2 of 3 How to Manually Eject a Stuck Disc in a PlayStation 5: step 2, image 3 of 3
    • If you are using a stand to hold your PlayStation, locate the screw at the bottom.
    • Using the flathead screwdriver, unscrew the 5mm Phillips screw from the base.
    • Remove the base, and place it off to the side.
  3. How to Manually Eject a Stuck Disc in a PlayStation 5: step 3, image 1 of 3 How to Manually Eject a Stuck Disc in a PlayStation 5: step 3, image 2 of 3 How to Manually Eject a Stuck Disc in a PlayStation 5: step 3, image 3 of 3
    • Place the PlayStation on the side without the PlayStation logo.
    • Pull up on the top right corner of the PlayStation . This corner can be found diagonally across from the disc tray. Pull the cover toward the disc tray, in a diagonal direction.
    • To remove the white cover, it may take some force.
  4. How to Manually Eject a Stuck Disc in a PlayStation 5: step 4, image 1 of 2 How to Manually Eject a Stuck Disc in a PlayStation 5: step 4, image 2 of 2
    • Poke a hole through the black sticker with the Philip's head screwdriver or spudger.
    • Use the screwdriver as a key to turn the screw inside the black sticker clockwise.
    • The disc should come out after several turns.
7 other people completed this guide.
Jason Pinto
283 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 7
Past 7 Days: 82
Past 30 Days: 380
All Time: 6,465
