How to Rehydrate a Dried Eyeliner Pen
  1. How to Rehydrate a Dried Eyeliner Pen, How to Rehydrate a Dried Eyeliner Pen: step 1, image 1 of 1
    • Before you start, test out your dried eyeliner pen so you can compare the results at the end!
  2. How to Rehydrate a Dried Eyeliner Pen: step 2, image 1 of 2 How to Rehydrate a Dried Eyeliner Pen: step 2, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the cap from your eyeliner pen.
    • Take a small pair of pliers and gently remove the felt rod from inside the liner.
    • Some liners may require you to unscrew the end of the liner to remove the felt rod.
    • If you do not have pliers, tweezers can also be used for this fix.
  3. How to Rehydrate a Dried Eyeliner Pen: step 3, image 1 of 3 How to Rehydrate a Dried Eyeliner Pen: step 3, image 2 of 3 How to Rehydrate a Dried Eyeliner Pen: step 3, image 3 of 3
    • Once the felt rod has been removed, gently place the rod in a bowl of warm water for no more than 30 seconds.
    • If you notice the colour of the water starts to change, immediately remove the felt rod from the water.
  4. How to Rehydrate a Dried Eyeliner Pen: step 4, image 1 of 3 How to Rehydrate a Dried Eyeliner Pen: step 4, image 2 of 3 How to Rehydrate a Dried Eyeliner Pen: step 4, image 3 of 3
    • Take the felt rod out of the water and immediately place it on a paper towel.
    • Gently pat the felt rod dry using a paper towel.
  5. How to Rehydrate a Dried Eyeliner Pen: step 5, image 1 of 2 How to Rehydrate a Dried Eyeliner Pen: step 5, image 2 of 2
    • Lastly, use a plier to fit the felt rod back into the liner pen.
  6. How to Rehydrate a Dried Eyeliner Pen: step 6, image 1 of 1
    • Now test out your new eyeliner pen to see the difference!
    • The red arrow shows the before and the blue arrow shows the after.
Finish Line
Nuha Naushad
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 132
